Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-27-2008, 10:00 PM   #1
jdfrmnt
Question carb spacer info
right now i have a 350 2 plane intake headers mild cam i was wondering if a carb spacer would help power and if open or 4 bore is better any info will help thanks
jdfrmnt is offline   Reply With Quote
Old 04-28-2008, 01:29 AM   #2
chevy72blu
chevy72blu's Avatar
Re: carb spacer info
Depends on who you ask. The best answer I can give you is every motor is different and you MAY gain power with one. Open spacers help with top end HP while 4 bore spacers will produce a little more torque; but, you may actually loose power with either. They are pretty cheap, and a lot of people have em laying around. I suggest taking a few different sizes and go out to the track- write which one you used on each time slip and dont make any other changes.
Wood spacers can help with keeping heat from transfering from the intake to the carb
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 04-28-2008, 07:12 PM   #3
djracer
djracer's Avatar
I vote for wood also!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
