Old 05-27-2008, 08:25 AM   #1
Square84
I don't think these pills work
Square84's Avatar
lowering the burbs
i wanna lower my 90 burb not sure how much though. any pics of lowered burbs would be greatly appreciated.
SQUARE84
90 SUBURBAN
Square84 is offline   Reply With Quote
Old 05-28-2008, 02:20 AM   #2
GMBowtie79
Surviving, one day at a time!
GMBowtie79's Avatar
Re: lowering the burbs
It's not a 90 but mines got a 6"drop in back 3" drop spindles 1"springs with 1 coil cut which dropped the front 5" or so.
79 Burb,350,tremic 5 spd, 4 wheel disc, daily driver
74 swb,350,350,driver & future project
"There's no such thing as a finished project"
GMBowtie79 is offline   Reply With Quote
Old 05-28-2008, 05:58 AM   #3
Square84
Square84's Avatar
howd you drop the back just a flip and notch
SQUARE84
90 SUBURBAN
Old 05-28-2008, 05:59 AM   #4
Square84
Square84's Avatar
the aqua and white looks good btw.
SQUARE84
90 SUBURBAN
Old 05-28-2008, 07:20 PM   #5
Bad Karma
Magnificent bastard
Bad Karma's Avatar
Nice looking burb! I was running a 4.5" drop up front, but I kept destroying my lower control arms.
What size wheels and tires are those?
1977 Big Block Burb
Bad Karma is offline   Reply With Quote
Old 05-28-2008, 10:47 PM   #6
GMBowtie79
GMBowtie79's Avatar
Yes its a 6" flip, I haven't noched it yet so it dosen't have alot of suspension travel.
Old 05-28-2008, 10:52 PM   #7
GMBowtie79
GMBowtie79's Avatar
My control arms don't hit, the crossmember has bottomed out mostly going tall speed bumps. rims are 20x8.5 all the way around tires are 245-40-20 in front and 265-50-20 rear
Old 05-29-2008, 12:02 AM   #8
Bad Karma
Magnificent bastard
Bad Karma's Avatar
I was running 235/60-15's on the front, which are about 1.6" shorter than your front tires. Hmmm, maybe I should go to 20's and drop my Sub back down again, I like the stance on your truck.
Or I could just bag it, but I'm not a fan of air suspension...
1977 Big Block Burb
Old 05-29-2008, 02:11 AM   #9
GMBowtie79
GMBowtie79's Avatar
when I put my 15" ralleys on it goes down about 1.5" and grinds on everything thats when I decided on puttin 20s on it! I want to bag mine eventually but the back is a b#*ch! nobody makes a kit and there are body mount issues and other cr*p! so I'm holding off for now. I'd love to put a dropmember in front but there is no point if I cant do the back. If I do it I want to lay frame! I'll just stay with the static drop until I win the lottery or inherit a fortune!
Old 05-29-2008, 05:02 AM   #10
Square84
Square84's Avatar
on cardomain ther is an orange one owned by a guy named josh its bagged and sick as hell.
SQUARE84
90 SUBURBAN
Old 05-29-2008, 05:41 AM   #11
GMBowtie79
GMBowtie79's Avatar
Ya I've seen that one before, that thing is bad. I wouldn't want to pay for his gas. mine is hard enough to keep gas in mine at $4.00+ a gallon. you know that big block sucks it up. there is another thread on here with a bunch of bagged burbs. the thread is called "post pictures of your favorite suburbans." do a search there are some sick rides in that thread!
Old 05-29-2008, 05:56 PM   #12
Bad Karma
Magnificent bastard
Bad Karma's Avatar
I have a 454 in my Sub and it's well tuned and maintained and it still only gets 7 or 8 mpg around town... It costs me almost $20 a day to drive to work!
Dropping the rear all the way down would definitely have to be a custom job. I was fine with a static drop in the rear, but now I'm thinking if I bag the front, I can avoid damage to the control arms a little easier. What the heck, it's only money, right?
1977 Big Block Burb
Old 05-30-2008, 02:24 AM   #13
GMBowtie79
GMBowtie79's Avatar
Mine has a 350 with a 5spd manual 3.42 rearend gearing and I'm lucky to get 10-12 in town. I'm building a new 350 cuz I don't know how many miles are on mine it's the 3rd truck that I know of that its been in. So I figure it's tired and worn. It's just hard to do things to my truck since I live in a apartment and don't have a garage. I've built mine in my carport a little at a time so I don't piss-off my landlords to much! That and being unemployed with 5 kids is puttin the brakes on alot of things I want to do to it.
Old 05-31-2008, 06:42 PM   #14
87 dually burb
my short bus
87 dually burb's Avatar
you have a build page or any other pics
I'm doing a flip in my duallie sub but I worry about the tires hitting the body
cause 1 is under truck and one is in the flare may have to cut the fender lip out I have 235/85/16 on dually rims
old dirty pic I had
**90 burb**bagged,shaved**(about done)*********
**91 burb**stock worker for now****************
*********only squares for me******************
87 dually burb is offline   Reply With Quote
Old 05-31-2008, 09:19 PM   #15
GMBowtie79
GMBowtie79's Avatar
I found this site after I dropped mine so there is no build thread. what pictures are you looking for I might be able to help. from what I understand the 1ton duallys suspension has some differances than my 1/2 ton but I'll do what I can. I was kinda thinkin about doin a phantom dually with mine and running some 20x15 in back with some MT 29x18x20 Sportsman S/R's. I think that would look sick and keep the back end planted around corners.
Old 01-08-2009, 10:44 PM   #16
justpball
justpball's Avatar
post some more pics gmbowtie79
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 01-09-2009, 08:30 PM   #17
GMBowtie79
GMBowtie79's Avatar
Ya heres a few more:
Old 01-11-2009, 07:17 PM   #18
87 dually burb
my short bus
GMbowtie79 I wanted to know how much clearence you have in the rear above you tires to wheelwell
if the chart is right you rear tires are 26.3" tall
my 255/30-22's measure 28" tall just wanted to see if a flip will work or should i do a hanger/shackles kit for adjustment
Old 01-13-2009, 08:57 PM   #19
GMBowtie79
GMBowtie79's Avatar
Dually, my back tires are approximatly 30" tall. I have 3" of clearence from top of tire to the wheel well. I hope this helps. when I first lowered it it had 31-10.5-15's 0n rallys and they didn't rub either. I don't have a notch so there isn't alot of travel to start with.
Old 01-13-2009, 10:26 PM   #20
87 dually burb
my short bus
cool that will help alot cause my stocker's have 31" and will be my winter tires
