Old 11-06-2002, 05:20 PM   #1
jay-dawg
chevelito
jay-dawg's Avatar
Lightbulb airbag hard air line ???s
Hi guys,
I was wondering what it would take to run hard lines instead of the plastic air lines.
Any pros and cons about using hard lines?
1) What type of lines to use (copper, aluminum, stainless steel?)
2) How to go about connecting pieces.
3) Type of connectors to use at joints.
4) What size OD to use if I want to use 3/8 valves
thanks,
jay
New deadline...when my son can drive.
Aloha from Honolulu, HI
jay-dawg is offline   Reply With Quote
Old 11-06-2002, 05:40 PM   #2
BaggedC10
Under construction!
BaggedC10's Avatar
Hard line is great, as long as you don't install copper. Go with SS and you will be very happy!
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 11-06-2002, 07:20 PM   #3
love it loud
Calibration Engineer
love it loud's Avatar
what's wrong with copper? I'm guessing it can't hold enough air pressure for bags or somethin?
love it loud is offline   Reply With Quote
Old 11-06-2002, 08:00 PM   #4
BaggedC10
Under construction!
BaggedC10's Avatar
It tends to break easily and not seal nearly as well as other materials. Plus, it looks like crap when the finish is oxidized after a short time.
Old 11-08-2002, 09:30 PM   #5
70 Jimmy
aka Crusher, Crushergmc
70 Jimmy's Avatar
Stick with poly lines. They are cheaper and hold the air just fine. I use them every day at work in critical applications (a leak would be devistating to the pricess) with no problems. If your really paranoid about leaking fittings, go with a swedgelock design. And remember, teflon tape is not a "sealer", it's more like a lubricant that allows the fittings to go deeper into the tapered NPT thread. We all know that deeper is better
"KEEP IT DOWN!"
70 Jimmy 454 2wd
56 GMC Big Window
"It's funny till someone gets hurt, then it's freakin' hilarious"
70 Jimmy is offline   Reply With Quote
Old 11-09-2002, 12:16 AM   #6
jay-dawg
chevelito
jay-dawg's Avatar
I know the poly lines work fine because I have it for the bags in my back in my s10. I just want to go a step further (read as "being anal"):p I also use the liquid teflon (I forgot what it is called). Anyway, thanks for all the input. I also got replies at sportruck.com
jay
