Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 06-02-2008, 01:24 PM   #1
nightmare
nightmare's Avatar
'91 S-10 blazer idle problem
Hey everyone, I'm normally on the 67-72 side, but my dad has a problem with his s-10. When he does a cold start, it will idle to fast idle for a few seconds, then go to low idle like it should. But when it gets to low idle, it will idle down further like it wants to die, then goes back to low idle. It cycles like this until it is warm, then it idles like it should. We’ve tried replacing the MAP sensor, the O2 sensor, all plugs, wires, dist cap and rotor, all with no resolution. The next thing that he wants to try is to pull the gas tank, and replace the fuel pump, but it is getting fuel. Would a bad EGR valve do this? What about a bad catalytic converter? The truck has 200k miles, but runs like a champ when it does run. It’s the 4.3 TBI. Any ideas?
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 06-02-2008, 05:49 PM   #2
trailwart
trailwart's Avatar
Re: '91 S-10 blazer idle problem
check the cts and there is another 1 i thionks its the iac. also the egr if not properly working can cause eradic running. pull it off and clean it, have a new gasket ready to go on and put a skim coat of anti seaze on the gasket so it can be removed for cleaning next time.
72 chevy 3\4 ton 4 speed 4x4
84 1\2 ton 4x4 (gone but not forgotten, thanks for the memories)
1999 suburban 4x4
1982 chevrolet S-10 V-8 (Thanks uncle EARL)
trailwart is offline   Reply With Quote
Old 06-03-2008, 10:10 AM   #3
nightmare
nightmare's Avatar
Thanks trailwart. I'll have him take a look at possibly replacing the egr. What is the cts though? Also, if the iac is what I think it is, isn't that the sensor in the air hat, close to the heat riser? I guess that is functioning properly. It does the same thing whether or not the air breather is on the tbi or not.
Mike
67-72 FAQ
Old 06-03-2008, 03:22 PM   #4
trailwart
trailwart's Avatar
cts coolant temp senser. not sure if yours has 2, but they tell the computer the temps so it can adjust fuel. if its not working right it could send the signal to dump fuel and the 02 is telling it its rich so it can get lost and rpms will go up and down, up and dopwn
1999 suburban 4x4
Old 06-05-2008, 11:20 AM   #5
likaroc13
Rollin' Old Skool
my '88 4.3 auto does something similar...when i first crank it (cold or warm), it idles up high for a few seconds...then it'll idle down to normal...i mean, i have to wait for it to idle down before i can put it into gear...i wasn't sure if this is normal either...my brother even asked me the other day if it was supposed to idle that high....but mine is fine after it idles down...the only other time is when you come to a stop in gear & under load, it vibrates really bad...but then it smooths out when you accelerate or even if in park/neutral
