06-05-2008, 08:37 PM | #1 |
Rear Bags in Place of Coils Q?
Who makes a set-up like this?My chassis is set up with 6" drop coils.I know this is pushing it w/o a C-notch.I plan to haul and tow so I want to got with air suspension back there so I can keep it off the frame.No C-notch wanted on this truck.
06-05-2008, 08:50 PM | #2 |
Old member
Re: Rear Bags in Place of Coils Q?
I'm not using them in place of the coils but with them. I measured them and foundout they have about any kind you need. I had to order them from Jegs though.
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. http://www.airliftcompany.com/online_catalog.html
06-05-2008, 08:57 PM | #3 |
Retired Air Force Veteran
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
06-05-2008, 09:32 PM | #4 |
Early Classic has a setup also.
06-05-2008, 10:58 PM | #5 |
I`m lazy.I`ve been meaning to look at ECE but don`t have the website saved.I have to type all that out...getting tired thinking about it,zzzzzzzzzzzzzzz
Andy,Are you saying I ould get bladders,like AirLifts,for inside my 6" coils?I don`t mind maually filling when needed to save a few bucks until I refine the truck.
06-05-2008, 11:01 PM | #6 |
Happy to be here
Just replace your coils with bags and use schrader valves to fill them. Clean and simple and works very well. Forum member Scoti has the scoop on what you need...
06-05-2008, 11:26 PM | #7 |
Old member
Yes these bags go inside the coils and you put air manually into them. You don't even have to take the spring out to install them. I ordered mine yesterday just for the bottoming out when I hit a hard bump in the road. I have a old vacume pump my dad gave me years ago with a single gauge for air shocks he use to run for the camper. It's a GM part. I plan to use it for filling the bags when I need to.
The pump works off the engine vacuum and you have a gauge in the cab to see how much air is in the system.
06-06-2008, 07:18 AM | #8 |
06-06-2008, 07:29 AM | #9 |
Those air-lift bags work excellent and they cost 78 bucks.What a deal.I run them with a 70-72 Monte Carlo spring.It gives a nice soft ride,and you adjust the air pressure accordingly.If you have to haul something,just air them up a little more.
06-06-2008, 06:13 PM | #10 |
The biggest issue with the ECE bags are they are $200 a piece for the bags. They are nice riding piston style ones like the big trucks use but two regular ones with a schrader or that Air Lift kit would be the way to go.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
06-06-2008, 07:38 PM | #11 |
I`ve used the AirLifts with standard springs by vehicle application.But,you can specify a dimension?I may eventually go with the true air-ride,but I have the new coils mounted and alot more to do on the truck.Once built it will definately get refined.Like a Gear Vendor coupled with the M22.Dig that,split all 4 gears when profiling.
06-07-2008, 11:47 AM | #12 |
Old member
Tim,
just call them (air lift) with ID of spring and height of it at ride height they will give you a part number as I did. Then call summit or jegs for the price. They are speical order so it was a little more $ 100.00 shipped.
06-07-2008, 05:15 PM | #13 |
Andy,Is yours lowered?How much?
06-07-2008, 08:07 PM | #14 |
Old member
I'm 3" in the back. I measured the height and it was 5 1/2" tall sitting normally. I have no notch either so it would bottom out on hard bumps I hope this will solve this problem.
06-07-2008, 08:21 PM | #15 |
Thanks.II just have a bare chassis now.I guess I`ll have to wait to measure.I have 6" drop springs which you can get away with w/o a notch and are carefull.That`s why I want bags to air up if I haul.I figured you`d be fine with 3" drop w/o air lifts.
