Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 06-10-2008, 08:00 AM   #1
PA-IndianRider
PA-IndianRider's Avatar
Question GOODYEAR "Front Runners" ?????
Have a chance to pickup a set of Goodyear "front runners" for a good price.... only 4 passes on them. Wondering if the will be OK for my C10 .... or should I wait for a "taller set"????
They are: 23.0 x 5.0 x 15
I know they make these tires for a good reason ....
John aka "Milner"
PA-IndianRider - Pittsburgh, PA
70 Chevy C10 Stepside
"Gasser/Altered Drag Race Hot Rod"
Where were You in '62 ?
PA-IndianRider is offline   Reply With Quote
Old 06-10-2008, 08:50 AM   #2
Marv D
Registered Truck Offender
Marv D's Avatar
Re: GOODYEAR "Front Runners" ?????
23's are short,, REAL short, reaction times and roll-out will be pretty darn quick. Heck I am running 26's on my chevy II and they barely fill the wheelwell. Myself, I'd thnk the 23'" tire would look silly on anything but an open wheel altered. But that's just my 2cents
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 06-10-2008, 09:37 AM   #3
bigjimzlll
bigjimzlll's Avatar
agreed^^^^^^^ I run 28"
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 06-10-2008, 10:16 AM   #4
RatPwrd72
RatPwrd72's Avatar
The Front Runner tires are a definate drag only tire. For a cheaper alternative, go to your local tire shop or online tire store and find a 185/65/15. We've been running these with good luck and bought them locally for $60 a piece. I wouldn't consider running anything less than a 27" tall tire.....
1972 Chevy Cheyenne Super- Pump gas 496,TH-400, TCI Stall, 3.73's,Ochre & White two-tone w/Olive
Interior
1967 Chevy Short Step Drag Truck-Iron Headed 468 Making Memories
My momma took me off the bottle years ago.....
RatPwrd72 is offline   Reply With Quote
Old 06-10-2008, 10:42 AM   #5
PA-IndianRider
Originally Posted by RatPwrd72 View Post
....... I wouldn't consider running anything less than a 27" tall tire.....
My "gut feeling" was that they were too short"....but I was not SURE!
Like I have mentioned before there is soooooo much about building a vehicle that is "correct" for the strip I do NOT know about..... Thanks for the info & tips.
John aka "Milner"
Old 06-10-2008, 03:48 PM   #6
Marv D
Marv D's Avatar
Only thing I'll add about the passenger tire,, check the speed rating if your going to be running seriously fast. Most passenger tires are only rated for 86MPH. You do not want to be doing 120+ and have a $35 tire come apart on you
Old 06-10-2008, 04:08 PM   #7
PA-IndianRider
WoW.....dahhhhh I never thought about that..... I do have a pair of 25" street radials (165's) that I do plan to use on the street for at least awhile (setup) but it never dawned on me about the top speed issue. Not that I'm planning on doing 120 mph in the 1/4.....although doing that with single-carb383 stroker ALL-motor would be awesome....ha!!!!
Will keep looking for "taller" front runners, Moroso or Mickey Thompson drag front tires..... still PLENTY of swap meets to go to this season.
BTW.... got a solid lead on a 400 turbo with 3800 stall setup for drag racing & also a "narrowed" 9" F**d rearend with Summers axles.
John aka "Milner"
Old 06-10-2008, 05:11 PM   #8
Marv D
Marv D's Avatar
Just to clarify,, I wasn't trying to say all passenger tires are are rated at only highway speeds, but there are more than just a few that are,, and more than a few are Z rated. Just be cautious and check the speed rating if you do use a standard passenger tire.
Old 06-10-2008, 07:45 PM   #9
RatPwrd72
RatPwrd72's Avatar
Good point, the ones I have are rated to 120......Which is what it was running with the old motor. Hopefully, the next bullet will push it a little faster.
Interior
Old 06-13-2008, 08:33 PM   #10
blackedoutharley
Here is the breakdown on speed ratings for passenger tires.
Keep in mind that some tires have a "P" in front of the size; this is not the speed rating! Also others have it included in the service index which is typically just past the tire size and will look like "92H". The letter is the speed rating, the numbers are the load index.
Speed ratings are based on indoor wheel test with the tire at max psi and load.
J = 62 mph
K = 68 mph
L = 75 mph
M - 81 mph
N = 87 mph
P = 93 mph
Q = 99 mph
R = 106 mph
S = 112 mph
T = 118 mph
U = 124 mph
H = 130 mph
V = 149 mph
W = 168 mph
Y = 186 mph
Z = 150+ mph
J through Q are typically assigned to large truck tires.
Hope this helps.
blackedoutharley is offline   Reply With Quote
