07-08-2008, 01:20 PM | #1 |
It's back and slmost ready!
Well my truck is back from my chassis builder and I've been working on it every night after work till 11:00pm for the last week trying to get it done for this weekend. No time for celebration pics just yet maybe tomorrow night, or Thur. before it goes in the trailer I'll snap a few.
Anyway truck is now 100-125lbs. lighter then last time it was there scaled 4003lbs. with 1/4 tank fuel. last time 4128lbs. with about 2/3 of a tank. The front drag springs settled too much though and couldn't get another pair that day so I'm not running the springs I wanted for some wheels up launches that only looks cool but eats time anyway. Incase anybodys new or didn't see and or care to read last post I made on the upcoming changes they are as follows. Tubular front upper and lower arms (Fat Man some day but not in the budget this year), dual pistion aluminum calipers and QA1 adjustable front drag shocks, 2" drop spindles and new small block springs. Willwood master cylinder, and Willwood 4 pistion discs in the rear. Narrowed Comp Engineering 9" fab housing, Moser aluminum center section, spool, and 35 spline Moser axles. New Comp Engineering 4-link, notched frame rails and QA1 coilovers with a 31x16.5" tire in the rear now. Pro Systems Nitrous Pro IV 1000cfm carb, fed by a Areomotive A1000 pump and A2000 return reg. system, on the carb side and a Areomotive non-return system reg. for the nitrous side. And a Harwood glass cowl hood to cover it all. And that's about it, a couple of changes and a few new parts.
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs Last edited by 71Dragtruck; 07-08-2008 at 01:28 PM. |
07-08-2008, 01:33 PM | #2 |
Re: It's back and slmost ready!
Sounds sweet I hope it totes the mail! Can't wait to see the pics!
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
07-08-2008, 11:01 PM | #3 |
Few pics.
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs |
07-08-2008, 11:03 PM | #4 |
more
07-08-2008, 11:14 PM | #5 |
Wow, that is awesome!
Can you tell me where you got the adjustable valve for the rear brakes? I like the looks of it.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 |
07-08-2008, 11:18 PM | #6 |
Thanks, it's a Willwood valve, Summit, Jegs most performance places can get them for you. I'm in Canada got mine from Mopac.
07-08-2008, 11:29 PM | #7 |
lookin way sweet! Can't wait to here the new times!
07-08-2008, 11:44 PM | #8 |
Thank Dj, saw your motor pics I was lost for words but feel your pain!!
Once I get things sorted out I'll likely go to a 180 shot and hope to see low 10's with that??
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs Last edited by 71Dragtruck; 07-08-2008 at 11:46 PM. |
07-08-2008, 11:44 PM | #9 |
What control arms are those and where did you find the alum calipers?
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
07-08-2008, 11:52 PM | #10 |
Daily Driver
Nice..... can you post up a pic of the rear showing how wide tires are. im looking to fit some bigguns and wanna see if a 32x14.0 will fit on a 12'' wheel with a 8 inch backspacing, from sidewall to sidewall they are 18'' on a 14'' wheel. im hoping going to a 12'' wheel will suck it in some and i can tuck the tire. any help would be greatly appreciated, thanks
nitrous...the equal opportunity destroyer. |
07-08-2008, 11:57 PM | #11 | |
http://www.howeracing.com/Braking/In...ton-Double.htm
07-09-2008, 12:02 AM | #12 | |
07-09-2008, 10:16 AM | #13 |
Man that is a clean truck . What lower control arm is that ? How much weight difference from the stock one ? You know Harwood test fitted those hoods on my truck . My friend worked there and he even gave me one but I traded it off to the guy who fixed my steel hood for me . Does yours fit good against the fenders? Mine had a huge gap (you could see the flat edge of the fender seam under the hood)
NHRA Super Street 469C It only runs 10.90 at 156 mph |
07-09-2008, 11:04 AM | #14 | |
07-09-2008, 03:27 PM | #15 |
This is a sick set up... im subscribed.
69 c-10 BBC 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build. |
07-09-2008, 04:05 PM | #16 |
71,
That truck looks GOOD!! The hood really looks good on it. I wish that Harwood made a hood for the '60-'66s, as I would have bought on from them. Have you ran it since you put the Pro-Systems carb on it? I'm kinda curious how much difference you'll see with it. What carb was on it before? The truck really looks good with the lowered stance!! Let us know when you make some passes with it!
Chris 1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas 7.02 @ 95.8, 1.45 60' 1965 Chevy C10 LWB, 355 sbc, TH350, daily driver |
07-09-2008, 04:13 PM | #17 | |
Thanks, I havent run it with the Pro Systems carb yet, I had a Mighty Demon 850 on it before this. Hope to race this weekend, I'll keep ya posted.
07-09-2008, 11:55 PM | #18 |
Here are a couple of quick pics Couch, sorry they turned out so dark, light was bad.
07-10-2008, 12:02 AM | #19 |
I was lookin at these wondering if they might work for me..
http://store.summitracing.com/partde...5&autoview=sku
07-10-2008, 12:09 AM | #20 |
Daily Driver
nice i love the truck .good luck and cant wait to see pics and videos of it at the track
07-10-2008, 12:09 AM | #21 | |
07-10-2008, 07:59 AM | #22 |
Will do.. I'm not sure where to start on the weight reduction first though. So I just bought a game scale that goes up to 550lbs. Since the truck is apart for the most part, I'm going to start weighing things, then divide the weight savings by cost. Figure I'll start with the most cost effective parts..
07-10-2008, 08:53 AM | #23 |
Awesome!
Just a little something to think about, it is not legal (NHRA) to mount a fuel pressure regulator on the firewall. |
07-10-2008, 09:34 AM | #24 | |
I know where your coming from though, when I first ran my old N2O fuel system I had the reg. mounted direct on the firewall and got busted by tech the first time out. That's when I built a extension to move it out 7" and no problem after that (even though it didn't look any safer to me) they were happy so I said that's much better hey, because getting on the bad side of the tech guys is a loosing battle, seen guys do that before LOL!
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs Last edited by 71Dragtruck; 07-10-2008 at 09:42 AM. |
07-10-2008, 09:57 AM | #25 | |
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs Last edited by 71Dragtruck; 07-10-2008 at 09:58 AM. |
