07-09-2008, 03:51 PM | #1 |
Eng/fuel layout set up
So after reading all kinds of others layouts i am at the point in the build to start getting it mocked up.
I am stuck between an Electrical and Mechanical fuel pump. I will be doing more street then track. But I will also add a 150-200 shot (the eng will handle it) and I assume that electrical is the way to go. Will a mechanical hold up and be easier? How many Psi do I need in a pump? How do I get more fuel when I hit the button so I dont starve it? What style fuel return should I run? Rubber or tube fuel lines? I am looking at low 11s street and low 10s on the juice. My sig will give you my eng specs. Pics of your set up with a description would help.
69 c-10 BBC 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build. |
07-09-2008, 04:10 PM | #2 |
Re: Eng/fuel layout set up
Best life from a electric is a flow through return style pump, it will run cooler and be easier on the pump. I'd also use steel braded line for durability and ease of installation. A good pump that can supply both motor and nitrous is prefered, from there run a seperate nitrous regulator off your return reg that will allow you to set the enrichment flowing pressure to where it needs to be. I also found that cheap Holley regs creep, I had 3 of them and all did it IMO they are junk, Areomotive is a very very good quality product but expensive.
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs Last edited by 71Dragtruck; 07-09-2008 at 07:25 PM. |
07-09-2008, 09:46 PM | #3 |
I agree with the above...with one caviat. If you look at pro-mods or and 10.5 outlaw class N20 car, they will be using the cheap holley regulator. tO KEEP THEM FROM CREEPING YOU CAN RUN A RETURN (SORRY FOR CAPS) line from the regulator back to the cell. use a .020 N20 jet at the regulator. This will also help with the momentary lean condition at activation.
Read this thread. http://www.yellowbullet.com/forum/sh...ad.php?t=45628
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA Last edited by bigjimzlll; 07-09-2008 at 09:48 PM. |
07-09-2008, 10:17 PM | #4 | |
mini truck racer
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
07-09-2008, 10:21 PM | #5 |
So i am a newby to NOS so fill me in on CREEPING... Benefits, Disadvantages, use on street application/racing...
07-09-2008, 11:30 PM | #6 | |
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs |
07-09-2008, 11:45 PM | #7 |
Here's the pics and info you wanted from me. In the other pics I posted you can see my pump at the back, 2-8an lines with filters come from my fuel cell and into a y block, they feed 1-10an into my pump and a 10an out from the pump to my main reg ( the red and black one). The reg has a 8an out the bottom back to my fuel cell (this is the return line), on my reg there are 4-8an outlets 2 go to my carb 1 for each fuel bowl with filtered fittings. The back one goes to my nitrous reg 8an in and out to a 6an line with a filter and pressure switch to the fuel solenoid. The front outlet just has a gauge in it.
Now like I said in our pm's my system is overkill and can be done cheaper, for instance you could use a A1000 return style reg with 2 outlets, use one to feed a dual inlet rail for your carb and the other to feed your nitrous reg. this will save fittings hoses and a bit of money. Mine is setup the way I wanted it (with a good budget) as the last fuel system I was ever going to build with plans of maybe a 632 BBC in the future. and with a reg. change it will handle EFI.
07-10-2008, 12:34 AM | #8 | |
07-10-2008, 12:55 AM | #9 |
I saw how you have yours plumbed and I was going to mention it.
Having the N20 plumbed off the carb regulator will flow great at idle. Where you can get into trouble is down track flow. When the carb bowls empty you can have fluctuations. The suggested way is to use a fuel log plumbed from the pump...then the carb regulator furthest from the pump plumbing with the N20 regulator(s) in between. With this set up it's not needed to return/bypass with a smaller jet. I am going to add a plate system(alky enriched) to mine. Only a 200 shot. I will use a fuel log and a cheap holley reg with no bypass.
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA Last edited by bigjimzlll; 07-10-2008 at 12:56 AM. |
07-10-2008, 01:27 AM | #10 |
So bare with me here it's late and I'm tired LOL, but how would that be that much different then what I have minus the log? My reg is pretty much a pressureized log, as in if you look into it you can see out all the ports from the pressure side, and it holds alot of volume inside. Would a log make that much difference, am I just not getting it? I do see what your saying, and I'd understand how that would apply to a full dead end system to avoid double regging the fuel to the noid, but where as on a return system the fuel at the reg comes from the same place as before the reg, and it's just regulating how much fuel is allowed to return to the tank V/S a dead end system where it is regulating the supply, does that make sense? I was thinking of doing it with my return reg downsteam of everything then went with this. Maybe it will make more sense tomorrow EDIT: nope no clearer today?
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs Last edited by 71Dragtruck; 07-10-2008 at 09:51 AM. |
07-10-2008, 12:49 PM | #11 |
Well back to the old drawing board
From Areomotives web site. 4.) I’m using a bypass style regulator for my carbureted fuel system. I want to install a nitrous kit. How do I set up a second regulator, either static or bypass, to control nitrous fuel pressure? To avoid engine damage, be VERY careful with this one! As explained in FAQ:1 above, the bypass regulator creates pressure between itself and the fuel pump, so if set for 7 PSI, that is the total system pressure available. Adding a second bypass regulator and attempting to set it for a lower pressure than the primary regulator, would default the entire fuel system to the lower pressure, creating a potential lean-out condition. Connecting a static regulator to a typical bypass system, with no more than 7-8 psi available, creates insufficient inlet pressure to the static regulator (12-15 psi is normally recommended). The result is reduced fuel flow through the static regulator and/or poor pressure regulation to the nitrous fuel solenoid, another potential lean-out condition. Short of installing a separate fuel system for the nitrous (highly recommended), the only option is to raise the bypass regulator set-point to 15-25 PSI, creating enough line pressure to feed two static regulators, each set for the proper carb and nitrous fuel pressures desired.
07-10-2008, 01:21 PM | #12 |
Yea..That's what I was trying to say. Are you running a return regulator or does your pump have a return line?
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
07-10-2008, 02:06 PM | #13 |
On my junk I run a seperate pump for motor and nitrous fuel!
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
07-10-2008, 02:32 PM | #14 | |
I'm running a return reg Jim, I just ordered another static reg for my carb, have all the spare fittings already just need to plumb it in won't be that big a job. I'll be running the same return reg I now have with it returning at the reg only @18psi, with a static reg for my carb @8psi and another static reg for my N2O @6psi. Hows that sound? Sorry for the confusion ripdog, I'll post pics of the changes and explain what I did when I'm done.
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs Last edited by 71Dragtruck; 07-10-2008 at 03:49 PM. |
07-10-2008, 02:33 PM | #15 |
Ya that's what I was doing, but decided to go to one big pump instead.
07-23-2008, 11:26 PM | #16 |
Hay Team!!
It's really a matter of pref...if you want to safely run the nitrous and motor off of one pump.....you are going to spend a nice lil chunk of change on that pump. I prefer two separate fuel systems as djracer does. To me it's just easier to tune for the nitrous and rules out some other issues if you run into problems. JMO
But to answer the question of the original post....my pref method is two separate fuel systems. Mechanical or electric will work just fine on the motor side. Mount a cell and run another system (with electric pump) for the nitrous fuel solonoid. I don't have the money for a $300+ pump. I have a total of $100 in my nitrous fuel system from cell to noid. including a decent regulator.
1972 Chevrolet Cheyenne LWB "Orange and White" 8) |
07-24-2008, 01:01 AM | #17 |
Ya as I also said there are way cheaper ways to do it then I did. I ran 2 systems before and decided to go with one big pump this time instead. It's all a matter of choice, one mistake I made was I took the advice of someone I thought knew better instead of researching myself like I nomally do and had to change things a bit in the end. Here is how my system ended up, SO FAR it is working good and I'm happy with it, hopefully it won't give me any grief down the road, no pun intended.
07-25-2008, 12:16 AM | #18 |
Hay Team!!
Well....if it ain't broke.....don't fix it I'm a computer programmer so I live by those words
07-25-2008, 01:41 AM | #19 |
Well mine was broke, my main pump was getting weak. So new system was built this way with future plans of a pump gas 632 no nitrous, when the time comes the 2 static regs will be removed.
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs Last edited by 71Dragtruck; 07-25-2008 at 01:48 AM. |
11-20-2009, 01:31 PM | #20 |
Thought i would revive this as i am running mine this weekend.
11-20-2009, 07:54 PM | #21 |
Just a note I added a jetted return off my nitrous reg to my return line for a more steady pressure. If I had it to do all over again I would run 2 A1000 return regs instead.
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs Last edited by 71Dragtruck; 11-20-2009 at 07:55 PM. |
11-20-2009, 11:11 PM | #22 |
I ended up getting the Mallory 140... the summit, Earls, and a few other companies had the exact same -an 8 specs just summit was bunches cheaper so i got theirs.
11-21-2009, 12:54 AM | #23 |
looks like good stuff, seen a few guys at the track running it. As far as fittings, I've noticed Earls to have the nicest finnish that's about it, I don't have many of thier stuff in my system.
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs Last edited by 71Dragtruck; 11-21-2009 at 12:56 AM. |
11-23-2009, 10:18 PM | #24 |
got the majority of the fuel system run today. Have a 40 micron prefilter before the pump, i wil have a 10 micron filter pre carb... I used an 1/8in x 3in flat stock bolted to the pump and used some left over carb gasket between it and the frame so it should quiet down any viberations. the pump is about 3/4 in below the tank. any suggestions let me know.
11-24-2009, 03:32 PM | #25 |
Registered Truck Offender
I am not a big fan of those little line filters, but something is better than nothing. Think about a Mallory Comp 140 Filter (about the best there is for the $'s IMO) or at least the ol racing standard HPG-1 Fram. On the 'in' side you want as little restriction as you can possibly get. The out side will push through most any filter, no matter how dirty. But the 'in' side is at risk.
Run a 10 or 12g wire to the relay for you pump. Low voltage is what burns most pumps up, and Mallory probably a little more picky about voltage... well that and running dry, another BIG no-no. System is looking good. Nice work!
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
