Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 07-10-2008, 08:00 PM   #1
mothertrucker424
mothertrucker424's Avatar
stumble
i own a 1993 blazer with 4.3 vortec(aluminum intake) and on acceration it stumble then smooths out i threw plugs cap wires at it and a egr and a fuel pressure regulator and still the same any ideas
p.s-no codes
_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
1972 K10 4"lift 33"tires (soon to be bigger and better)
2000 silverado 1500 2wd 2"coil spacers3" BL 285/75/16's
mothertrucker424 is offline   Reply With Quote
Old 07-11-2008, 08:44 AM   #2
bowtier
Nobody rides free
bowtier's Avatar
Re: stumble
fuel filter or filters?
My '01 was acting similar, not so much from a stop, but more accelerating pulling hills. turned out it had 2 gummed up filters.
'71 C10 LWB 400SB/350TH
'86 K2O LWB 350SB/400TH-6" tuff country lift, Shackle flip - plow truck
'06 HHR - wifes wheels
'01 Blazer - daily driver
"It's better to burn out than it is to rust."
-Neil Young
bowtier is offline   Reply With Quote
Old 07-11-2008, 07:20 PM   #3
mothertrucker424
Re: stumble
also replaced fuel filter i will run a pressure test tomorrow
Old 08-29-2008, 10:44 PM   #4
68C15
blood type; Retumbo
68C15's Avatar
Re: stumble
did the pressure drop after you shut it off? (leaking regulator and/or plastic fuel lines inside the plenum)
68C15 is offline   Reply With Quote
Old 09-01-2008, 05:43 PM   #5
mothertrucker424
Re: stumble
yes i replaced reg. and lines and scrubbed inside plenum (fixed awhile back sorry for not replying sooner)
