Old 07-28-2008, 07:04 PM   #1
mag-d
Trans swap is 68 suburban
I have a 68 suburban C-10, factory 3 speed manual trans. I want to replace the 3 speed manual with a 350 turbo trans.
Does anybody know rather I need a short or long tail trans for the replacement, also do I need to replace the yoak on the drive shaft or will the factory original shaft work.
Your help is apreciated.
mag-d is offline   Reply With Quote
Old 07-28-2008, 07:44 PM   #2
JimKshortstep4x4
Re: Trans swap is 68 suburban
A short tail 350 will swap in and can use the existing driveshaft as is.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 07-28-2008, 07:56 PM   #3
mag-d
So is the splines on the 3 speed and the auto trans the same, and i can use the drive shaft as is
Old 07-29-2008, 07:42 AM   #4
JimKshortstep4x4
Yes, the splines are the same.
Jim
Old 07-29-2008, 04:11 PM   #5
GMCPaul
JimKshortstep4x4 called it right the only thing you need to change is the transmission, trans. linkage & transmission crossmember.
We carry a new style automatic trans crossmember here if interested
http://www.gmcpauls.com/auto.transmission.htm
for $70.00
GMCPaul
GMCPaul is offline   Reply With Quote
Old 07-29-2008, 04:13 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
and a rad with a cooler, linkages and linkage mounts, a column or an aftermarket shifter
Old 07-29-2008, 10:16 PM   #7
mag-d
Ya I forgot about the trans cooler, Im figuring on a Ididit colum, don't want a floor shifter. I was looking at a trans crossmember from classic performance.
I don't know If i will change radiators or run a external cooler.
Old 07-30-2008, 12:59 PM   #8
BlueJeep
BlueJeep's Avatar
Do an external cooler, they're much better at cooling the tranny than one in the radiator.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
