Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 08-04-2008, 05:33 PM   #1
stump
what can i fit behind stock bench?
87 reg. cab all stock interior.. want subs.. i have 2 10'' but they dont cut it.. any one fitting 12''? and how
stump is offline   Reply With Quote
Old 08-04-2008, 07:42 PM   #2
AceX
>130dB Moderator
AceX's Avatar
Re: what can i fit behind stock bench?
Pioneer shallow mount subs. JL Audio TW5's. Kicker CVT's. All will fit behind the seat and not restrict movement.
I used to have 2 10" Pioneer shallow subs in my truck and I think the biggest thing with those subs is that you have to feed them lots of power, otherwise they won't pound like you want them to.
You can fit amps under the seat or try and integrate them into the sub box. I've done both and prefer the under seat option.
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 08-04-2008, 07:45 PM   #3
stump
well my box fits in there fine but the front of the speaker seems to hit the seat when it extends out.. im not sure if it does but i dont want it to. also will shallow 12''s fit?
Old 08-04-2008, 09:23 PM   #4
hlmlh
hello
hlmlh is offline   Reply With Quote
Old 08-04-2008, 09:48 PM   #5
Riveted1
Tasty Cakes!
Riveted1's Avatar
Personally, I would look at your current setup and see if you could improve it. 2 good quality 10's in proper airspace with good clean power and crossed over correctly should jam.
We'll need more info on your setup though.
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 08-04-2008, 10:14 PM   #6
stump
well i have a jvc 200 watt head unit, no amp, no speakers.. just these subs.. i hooked them up with a freinds amp 250watt amp and they dont hit very good.. i should beable to put 350 watts to them before they pop.. the peak on them is 300 each so 350 togeather should be fine? i was thinking like 1000 watt amp (turned down) and in the door speakers. capacitor and maybe 2 more 10's with custom box. but id rather have 2 12's if i could get them in haha
Old 08-13-2008, 11:20 AM   #7
nvrsatisfied
nvrsatisfied's Avatar
i had a very similiar set up you have (mine was an 85' chev single cab) the shallow mounts answer a lot of prayers, the CVT's run roughly about 4" deep, that goes for the 10" and 12" the air space is what makes them great, you can do a small enclosure down to a .5 cu ft for the 12" and .4 cu ft for a 10" sub. thats really nice for a guy like me at 6'1'', also it does not take a ton of power to jam out the sub, a single 12" or 10" 2ohm sub on a ZX400.1 amp jams out really nice!!!!!!!
they are also in prefab boxes the top of the box is roughly a little under 4" on depth and the bottom of the box a little over 6''. as far as depth goes.
Lug Nuts Classic Rides. (Bodywork, small fab, and Restorations)
Perry, Ok.
We're just two guys, trying our best.
72 cheyenne super
https://67-72chevytrucks.com/vboard/...d.php?t=811512
55 chevy truck
http://67-72chevytrucks.com/vboard/s...d.php?t=840174
nvrsatisfied is offline   Reply With Quote
Old 08-15-2008, 01:01 AM   #8
SkylineNXS
SkylineNXS's Avatar
I just tackled this proble actually. Instead of mounting behind the seat, since my 10's have a 5.6" mounting depth, i built a bow center console style. I have a bench seat so it dropped the total volume to about 1.45 cu ft, but with a 2000 watt amp and 2 1200 watt 10's, it jams out really really nice. Just finished installing it tonight...seat all ther way back, which u have to install the seat after the box, makes for a fun time gettin the 2 back bolts in.
BRAD
2000 GMC Sierra EXT Cab Short 4x4, finally mine...
1966 C10 SWB Fleet, 250 I6, three on the tree....
Previously Owned....
1987 Chevy R10 "Silverado" (at least the badges were) Short Step 350 700r4....
1972 Chevy LWB Fleet 350/350
EXTENDED CAB ALL THE WAY!
.._..~...-...._...____
.._..-...______|_|__\____
..-..~.|_(O)__|_|__|_(O)]
SkylineNXS is offline   Reply With Quote
Old 08-16-2008, 07:53 AM   #9
Mr79C10
It Is What It Is,,,,
Mr79C10's Avatar
SkylineNXS
What year is your ride and what or did you run your lower vent for heat or air?
*79 C10 Short Box ST8 6 bang'r *
*Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT
*__--__*
79 C-10 project
.........................__
..............._____ l __\___
..............|_(O)_ |___(O) ]
FAQ INDEX Thread
The Kulture
My Rat Den
Mr79C10 is offline   Reply With Quote
Old 08-17-2008, 05:50 AM   #10
SkylineNXS
SkylineNXS's Avatar
Its an 87, and i have air but theres about two inches between the box and the air vent in the middle, so i think there should be enough room to not block the air...
BRAD
Old 09-13-2008, 03:22 PM   #11
frostie_122
JL 13TW5!!!! JL 13TW5!!! sounds like a w7, output of a w3, 2.5 " mounting depth.
frostie_122 is offline   Reply With Quote
