Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 08-09-2008, 11:35 PM   #1
Pyrotechnic
Pyrotechnic's Avatar
Automatic floor shifter
Looking for a automatic slap style shifter fit for a truck. Now I've seen the car style ones mounted high up, but this doesn't look good to me and it takes up a lot of real estate on the floor. I'd like something with a longer stick that's meant for a truck. Do these exist, and what you are all using in the way of shifters ?
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 08-10-2008, 03:06 AM   #2
redhead69
fugedaboutit
redhead69's Avatar
Re: Automatic floor shifter
They make a truck mega shifter that sits up a little more than the car version, but if you think they take up too much space check out the lokar products.. very slick
Currently truckless
redhead69 is offline   Reply With Quote
Old 08-10-2008, 08:12 AM   #3
69trk
69trk's Avatar
here's mine on some square tubing and a plate, i don't think it looks to bad.
69trk is offline   Reply With Quote
Old 08-11-2008, 10:47 AM   #4
regan wilson
regan wilson's Avatar
That instrument panel is cool !
NHRA Super Street 469C
It only runs 10.90 at 156 mph
regan wilson is offline   Reply With Quote
Old 08-11-2008, 08:50 PM   #5
67dragtruck
67dragtruck's Avatar
I agree with Regan and like your dash. They say that was redesigned to make the gauges more visible around the wheel. Is it a good improvement? If so I'm going to order one myself.
Tom
No more dragtruck for me. I'm building a new ride though. It's a '71 fleetside, 400 sbc, 700R4. Working on it now, finally. Soon to have Edelbrock Pro Flo EFI, Vintage Air, 1 piece windows, buddy buckets, etc.
My new build thread:
http://67-72chevytrucks.com/vboard/s...17#post2861817
Best pass with the old dragtruck:
5.32 @ 131.6 mph 1/8 mile w/ a 1.25 60' Fogger/Plate 2003
Best pass with the street 406 hydraulic roller motor w/ mild plate tuneup
5.93 @ 114 mph 1/8 mile w/ a 1.29 60' 2003 or 2004
67dragtruck is offline   Reply With Quote
Old 08-11-2008, 10:44 PM   #6
69trk
69trk's Avatar
Thanks, the dash is from nolimit. The only problem i had was that i had to trim some of the dash behind the guage panel where the lights and the windshield wiper switch were relocated. Other than that i do like it alot.
Old 08-11-2008, 11:17 PM   #7
Rodms
Rodms's Avatar
It depends if you want to bend over to shift,and if you want to shift fast or not,if so design a nice console and get a short shifter,and I agree thats a nice dash 69,I'm glad you all are'nt broke down now anyway,My $$**$$***+++ cam ate 4 in and 6 ex lifters I just found out today and its motor time again,I'm thinking about building the 400 SB now!!!
Built chevy tuff!
Rodms is offline   Reply With Quote
Old 08-12-2008, 12:21 AM   #8
Pyrotechnic
Thats a pretty good looking installation. Looks like the shift lever is right where it needs to be.
I may just bite the bullet and take a car style shifter and just build it up on a taller base. Probably the easiest solution.
Old 08-13-2008, 02:14 AM   #9
64chevkev
64chevkev's Avatar
The one I have in my truck doesnt have a push button or anything but it is longer than the car ones. It is made by B&M and is called the Unimatic. I am not sure what you are looking for but mine works good and it will work with just about any auto trans including overdrive trannys.
Name:  Resize of 100_0780.JPG
64 Chev c-10 LWB. 383 STROKER TH400 ps, pb.
64chevkev is offline   Reply With Quote
Old 08-13-2008, 08:24 AM   #10
85SBC400
i like that now.....makes me wanna install one of those in my truck.
85SBC400 is offline   Reply With Quote
Old 08-13-2008, 10:28 PM   #11
Pyrotechnic
That's good lookin, too bad it's not a ratchet style otherwise i'd buy one right now.
Whats everyone's favorite ratchet/slap style shifter for a street/strip truck that will see some track time ? I don't know much about these as I've never driven a vehicle with one.
Old 08-14-2008, 11:13 AM   #12
regan wilson
I use a B&M ProRatchet and love it . I have always liked a ratchet shifter becuase you cant miss a shift . You might could call them and see if you could change the stick out for a longer one . Another thing is if you plan on doing any racing you will need a reverse lockout and a neutral saftey switch .
Old 08-14-2008, 04:05 PM   #13
71Dragtruck
71Dragtruck's Avatar
Here are some pics of my old B&M truck Mega Shifter and my new B&M Pro Stick installed.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 08-14-2008, 09:57 PM   #14
hotrod 80
mini truck racer
hotrod 80's Avatar
I am a pro stick user also . I have the conventional handle and not the magnum . Also need to consider that when belted in the seat you have limited movement . If your belt are tight you need to be able to reach the shifter comfortably .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 08-16-2008, 06:40 PM   #15
Ford Assassin
Ford Assassin's Avatar
I like the Hurst Quarter Stick, but it need to sit higher to be useful in our trucks.
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 08-19-2008, 08:53 PM   #16
85sqbdy
85sqbdy's Avatar
I currrently use a B&M Pro Ratchet myself. Shifts are precise and you can't miss a shift. I use to use a pro stick, but found that, although the shifts are precise, when you get down in the 8.50 or quicker classes with a 3 spd. theres just to much to think about with a pro stick. I just like being able to use my shifft solenoid.
85sqbdy is offline   Reply With Quote
Old 08-19-2008, 09:21 PM   #17
69trk
69trk's Avatar
Here's a little better picture of my hurst quarter stick. Once it's out of park it's nearly perfect for shifting.
Old 03-14-2009, 02:00 PM   #18
Ford Assassin
I am seriously considering this shifter, is your truck a high or low hump?
Thanks!!
Cable
Old 03-14-2009, 11:32 PM   #19
AlienYouth
AlienYouth's Avatar
I'm rockin the truck mega shifter, i love it and i've got it at a perfect height, and i've got a bench seat, haven't gotten around to fitting the plastic console on it, but i will some day...
Picturesss
71 C10 383/TH400
13.65 @ 99... 2.06 60' spinnin :/
AlienYouth is offline   Reply With Quote
Old 03-15-2009, 01:02 PM   #20
70c10
67-72 Addict!
70c10's Avatar
I'm also using the truck version of the megashifter. Here is a pic showing the car version next to the taller truck version if anybody is interested. The car version base is easier to fit with a bench seat but I managed to get my truck version in by mounting the base backwards to avoid trimming
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 03-15-2009, 03:08 PM   #21
woodwright
Enjoying left field
woodwright's Avatar
I had an 81 stepside years ago, and a installed a B&M Quicksilver into the seat right next to me. In park the shifter ball was right on the edge of the seat, and in drive it was right in the middle about 4" high, right where your hand rests comfortably. It was surprisingly easy to do, and it worked great. Sorry I don't have any pics, the truck was stolen 10 years ago. I'm planning on doing this again in my 70.
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 03-15-2009, 08:40 PM   #22
djracer
djracer's Avatar
here's my shifter mount that also holds my procube delay box.
sorry I don't have a better installed pic
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 10-18-2009, 05:24 AM   #23
HighwayHum72
damn kevin, you drive one hellavu truck. i wonder whats it like.... and what it takes... thanks, that video there is some inspiration.
HighwayHum72 is offline   Reply With Quote
Old 10-28-2009, 08:06 PM   #24
Blue Gas
Blue Gas's Avatar
I made a stand out of a 3" exhaust pipe 45* bend to mount my pro stick on. I stole the idea from a 54 that was in classic trucks a couple of years ago.
1952 3100 5-window, work in progress
1985 C10, 454/th400
Blue Gas is offline   Reply With Quote
Old 10-28-2009, 10:06 PM   #25
djracer
djracer's Avatar
That's pretty Sexy!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
