08-18-2008, 05:17 PM | #1 |
Torque specs on lug nuts?
What are the torque specs on lug nuts?
15" factory wheels Thanks, David |
08-18-2008, 06:12 PM | #2 |
Re: Torque specs on lug nuts?
95 pounds I think but im sure someone will claify this for me
1967custom |
08-18-2008, 06:15 PM | #3 |
can i just ask why?
RN U OVR |
08-18-2008, 06:23 PM | #4 |
08-18-2008, 06:26 PM | #5 |
i have never seen anyone actually torque them specifically. everyone i've ever seen just tightens them as much as they can... within reason
RN U OVR |
08-18-2008, 06:56 PM | #6 |
Between Trucks...
X2
Beat it to fit, Paint it to match... |
08-18-2008, 09:13 PM | #7 |
20' Daredevil (Ret)
95 is spec on my Jeep with aluminum wheels. I am kinda picky about wheel care and warped brake discs, so I torque them every time -- as I do on our Tacoma. On the K20, I just tighten 'em with the four-way....
08-19-2008, 10:05 AM | #8 |
porsche, BMW and Toyota are all 95 pounds. Of course these are all aluminum wheels with disk brakes. I torque mines to 95 on the truck also simply out of habit
1967custom |
08-19-2008, 10:15 AM | #9 |
It really depends on the stud size - here's a link - http://www.tirerack.com/wheels/tech/...jsp?techid=107
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
08-19-2008, 10:18 AM | #10 |
100 foot lbs with a cris cross or star pattern on the 5 bolt. then retork at apx 50 miles again.
Trueman |
08-19-2008, 10:24 AM | #11 |
Trucks N Tranzams
Torquing the lug nuts provides an even force on the wheel and disc/drum. It will also prevent damage to your wheel. It is also recommended that you lightly grease the wheel stud as well.
Here is a reference...one of many if you google Lug nut torque specs. http://www.tirerack.com/wheels/tech/...jsp?techid=107
Don '68 Chevy LB 383 TH400/GV/373 posi '56 Chevy 4WD SWB '64 Chevy short stepside '79 Trans Am 455/TH2004R/12blt/4whldisc 95 Kia (Wifes car) 2002 S-10 extended cab pickup "God punishes small sins immediately" Last edited by Arad68; 08-19-2008 at 10:31 AM. |
08-19-2008, 10:29 AM | #12 |
Parts and more parts
I torque my lug nuts on my truck wheels to 100 lbs. religiously.
08-19-2008, 11:17 AM | #13 |
To everyone,
Thanks for the links and opinions. David |
08-19-2008, 11:45 AM | #14 |
yeah, i grease my studs ( i can hear the jokes now) every once and a while, make taking them off and putting them on alot easier, i just use disc brake grease, but i can see how adding some grease will help to eaven out the torque
'55 3100 2nd series short-bed stepside '70 Corvette coupe stingray '71 Chevelle 2-dr coupe SS clone '71 C10 long-bed fleetside '83 long-haired brunette wife |
08-20-2008, 12:59 PM | #15 |
Old member
Here is the torque.
07-07-2010, 12:05 AM | #16 |
Hand Crafted C-10
Yup, I do my '68 C-10 at 70-75#.
Just caught the tire shop today (IN TIME-whew) beginning to use an impact wrench on my wheels. Half ton 6-lug rotors are spendy. |
07-07-2010, 04:24 PM | #17 |
its all about the +6 inches
anti-seize or never seize is better to use on the studs than grease.
I have never seen an old school rotor or drum, nor a steel wheel get damaged from impacts, even the mega monster torque impacts they make these days. |
07-07-2010, 05:23 PM | #18 |
Torque specs are independent of application. They are based upon fastener material, fastener diameter and grade so, here is a handy table for steel (not Stainless) that is good for every application:
07-13-2010, 12:39 AM | #19 |
You really dont need specs the chances of hurting anything are pretty rare i use a impact on everything including my atv an i lug those things on tight an never had any problems.
07-13-2010, 01:03 AM | #20 |
lol at being worried about specs. I worked at a tire shop for 2 years and never had a complaint about anything. Just used the impact.
01-28-2016, 01:52 PM | #21 |
Old thread I know but....You impact gun guys are dinosaurs. Improper wheel torque can lead to several problems with the most prevalent being eventual lateral runout of rotors and pulsation of your brakes. Axles too can be distorted from improper torque. It's not really a matter of too tight or too loose but the inconsistency from lug to lug that causes the problem. Do you think engineers dream this stuff up to sell torque wrenches? I watch Powerblock TV on Sunday mornings and Ian from the Extreme 4X4 uses an impact gun for everything and people watching him think this is ok. Wheel nut torque is NOT dependent upon the size of the lug because torque for my 20 inch aluminum wheels on my 2006 Silverado is 125 ft.lbs. If I put my 17 inch steel rims on for the winter the torque spec is 90 ft.lbs. Why? Because 125 ft.lbs will pull the lug nut through the rim under stress. Torque specs can be ignored for a cross member bolt or maybe exhaust hangers and the like but running gear needs to be properly torqued to avoid problems.
01-28-2016, 02:03 PM | #22 |
I had a wheel fall off my 03 2500 HD because a tire shop used an impact instead of torquing the lugs. I always used the OEM torque specs. Another thing to add is lubricating studs/lugs. I spoke to a Rep. from the loctite company who specifically stated not use anti seize on lug nuts. It is ok to use on the wheel mounting flange but for lug nuts/studs he recommended light oil or grease.
01-28-2016, 03:42 PM | #23 | |
Overtorquing will keep them on, but it'll bend and warp rotors, damage lug nuts, and so on. Actually I use an impact with a torque stick and have been verifying with a torque wrench afterwards, but they're been within 3 ftlbs with the torque sticks, so I'm starting to trust them. Using an impact without a torque stick is, well, bush-league. If I caught a shop doing that to my car I'd certainly never take any work back there. The following carnage happened because the seller (I was the buyer) swapped wheels right before selling it and didn't torque them, I guess. Since I don't normally retorque the wheels as soon as I buy a car, you see what happened. Now I check lug nut torque! On the plus side, Hagerty located an NOS fender, door skin, rotor, and spindle. How I don't know, but they got all NOS parts for me.
01-28-2016, 06:27 PM | #24 |
Use German torque on them. Goodentight. Just kidding also the torque thing is most important on alloy wheels they need to be rechecked after a drive of just about any distance at all. I have had and seen more than one wheel run off because the wheel should have been rechecked and wasn't. Mostly though that applies to the alloy type wheels. Jim
01-31-2016, 12:36 PM | #25 | |
There are things to wave your hand at and say that's BS and isn't necessary and I'll agree to some of those but I don't understand how a guy can ignore the safety aspect of putting wheels on your vehicle and loading your kids in it and driving at 70 mph without paying attention to proper mechanics and do it right. I think the ONLY reason we don't see more accidents is the engineers have over engineered these parts to allow for the uninformed back yard mechanic. Be safe and do it right. Last edited by GMJimmy; 01-31-2016 at 12:58 PM. |
