Old 11-15-2002, 07:27 AM   #1
RED72blazer
urban fourwheelin
RED72blazer's Avatar
whats a RV Cam?
It's kinda a stupid question. but is a RV cam really out of an RV?
Can anyone explain this? thanks
matt
RED72blazer is offline   Reply With Quote
Old 11-15-2002, 08:51 AM   #2
Blazer1970
Blazer1970's Avatar
An RV cam is a mild performance cam that is designed more to make lower RPM torque than high RPM horsepower. This is the type of cam that would be used in an RV if you wanted to upgrade the motor.
Blazer1970 is offline   Reply With Quote
Old 11-15-2002, 08:53 AM   #3
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
No, it's just designed for RV'S and heavy duty towing so they call it an RV cam.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 11-15-2002, 12:37 PM   #4
RON WOODGEARD
Resident Young Old Dude !
BLAZER 1970 is right! An RV cam is a cam designed to be useful in the lower RPM range.. My pulling cam (RV CAM) is actually a pretty good street performance cam. and along with an AUTO, RV TORQUE CONVERTOR,LOW range manifold & carb set up,GEARS, ETC.ETC. My 350 was a very strong pulling engine. I pulled a 4 horse bumper pull horse trailer.
MY CAM SPECS,
DURATION, 272/282
LIFT, 442/465
112 center line
Useful RPM: 1500-5000
TORQUE: 0-3500
RON
RON WOODGEARD is offline   Reply With Quote
Old 11-16-2002, 01:18 PM   #5
ckhd
ckhd's Avatar
There aren't truly RV cams. It's a generalization of a type of cam profile. If the cam is designed to pull, have low end torque, etc... then people will generalize it as a "RV" cam. The cam I have in the '68 has been generalized as a "RV" cam, but when I bought it, it bought it for it's rpm range and torque aspects.
It's the same as a "3/4 race" cam. Really no such thing, but if it has tall lobes, and makes lots of horsepower at high rpm, but can still be driven on the street (with the idle cranked up to 1200rpm or something), then they call it a "3/4 race".
If you want a smart parts guy to take advantage of you, ask him for a "RV" or "3/4 race" cam. If you want what you need, call a cam manufacturer and give them the specifics of your engine (ci, compression, head flow, valve size, rocker ratio, intake/exhaust manifold type, carb info), vehicle, etc.. and tell them what you will be doing with the vehicle, and they will help you pick the right profile for your application. I'd say that Crane probably has at least 6 grinds that could be generalized as "RV" cams, and probably twice as many that could be called "3/4 race" cams.
If you have Desktop Dyno, you can plug in all of your engine specifics, including all the details of your cam, and see if the cam will do what you want.
The cam is the heart of your engine. Pick the wrong one and you'll hate your engine. Pick the right one, and you'll love it.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 11-16-2002, 05:00 PM   #6
RON WOODGEARD
NO SUCH THING AS A 3/4 RACE!!!!!!
Not any more, but to us old farts???!!! this was the way in which we bought a CAMSHAFT.
Before the extended technology there were VERY FEW cams to choose from IE: The race anology, 1/4,1/2,3/4,5/8,and fullrace. And I absolutely agree that a poor cam will really ruin your day, But I guess I still have more trust in a good cam company. You tell them you want an RV cam, and they will take it from there to ask the questions of it's intended usage at what RPM.Weight of vehicle,rear end gearing,Standard or auto, ETC,ETC,
You can do most of the research yourself by getting the camshaft spec sheets. they will tell you what rpm the cam is intended for, as far as H.P and TORQUE. I don't know of a major name cam. company that doesn't offer that information to you. If you are going to really pull with it then you don't care about HP you want brute torque, at the lowest possible RPM. But don't plan on any CAMSHAFT working in the low rpm range and not having everything else "MATCHED" (in other words don't use a cam. that's intended for 0-3500 rpm and install a manifold, carb. combo. that works from 2500-6500 rpm.
No 3/4 RACE CAMS anymore,???,,, Damned I am getting old.
RON
Old 11-16-2002, 05:13 PM   #7
Blue_71
Bloo
Blue_71's Avatar
i was playing around with cams on desktop dyno, and if you play enough you can find excactly what you need.. so far the highest ive got my motor to was 420 torque@2000 RPM, and i have to pull almost 9 tons with this thing (27500 lbs).. just pick a cam for what you need, speed or brute force
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 11-16-2002, 09:03 PM   #8
lukecp
Formerly yellow72custom
lukecp's Avatar
I always thought of a RV cam as one with 204/214 degrees of duration @.050 lift, and around .420-.440 lift. BTW, i have one in my truck and i am very happy with it. However....the power drops off considerably above 4500 RPM, but it runs really strong everywhere else.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
