Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 08-21-2008, 08:23 PM   #1
Kurt L
Kurt L's Avatar
high idle.
i have a 2001 blazer with a 4.3 v6 [vortec] that does not idle down during shifts 5spd.it seems like it takes a coupla seconds for it to fall down it wants to stay up around 1000 rpms before falling so you can shift.any ideas? wife complain bout it,it has bout 80,000 on it.
Kurt L is offline   Reply With Quote
Old 08-29-2008, 10:42 PM   #2
68C15
blood type; Retumbo
68C15's Avatar
Re: high idle.
is the TPS voltage staying high? what is the actual/desired IAC counts? vacuum leak?
68C15 is offline   Reply With Quote
Old 08-30-2008, 12:39 AM   #3
corn
Re: high idle.
Im guessing his answer would be the same as mine... Huh?
corn is offline   Reply With Quote
Old 10-10-2008, 10:09 AM   #4
Arad68
Trucks N Tranzams
Arad68's Avatar
Re: high idle.
Mine does the same thing. I bought several books to help. I'm gonna need 'em anyway. Mine acts up more in traffic when it's hot though.
Don
'68 Chevy LB 383 TH400/GV/373 posi
'56 Chevy 4WD SWB
'64 Chevy short stepside
'79 Trans Am 455/TH2004R/12blt/4whldisc
95 Kia (Wifes car)
2002 S-10 extended cab pickup
"God punishes small sins immediately"
Arad68 is offline   Reply With Quote
Old 10-10-2008, 03:43 PM   #5
BarryB
BarryB's Avatar
Re: high idle.
does it do it all the time or just while shifting. You can actually set you idle down but it's a complicated process. But I agree with 68c15. might need to check your TPS. It may be getting dirty and not going back to idle position as fast as it used to. Take it off and clean it, maybe some kinda of lube.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 10-10-2008, 11:19 PM   #6
Arad68
Trucks N Tranzams
Arad68's Avatar
Re: high idle.
Mine is intermittant and doesn't seem to be tied to shifting. It is most noticable when I let my foot off the gas. It doesn't immediately idle down or decelerate as it should.
Don
'56 Chevy 4WD SWB
95 Kia (Wifes car)
Old 10-11-2008, 08:39 PM   #7
Kurt L
Kurt L's Avatar
Re: high idle.
okay dumb question what is TPS?and where is it located at on the engine? i'm not very good, when it comes to all this electronic stuff.
Old 10-11-2008, 09:36 PM   #8
BarryB
BarryB's Avatar
Re: high idle.
T.P.S. Toilet Paper Supply
I am smart A*& I know.
It is the throttle position sensor. It usually located at the throttle body. I have to look to see if I can find a pic. That would easier than me trying to expalin where it is.
Two rules in life.
Old 10-11-2008, 09:49 PM   #9
BarryB
BarryB's Avatar
Re: high idle.
Here's a picture of a TPS.it is located on your throttle body.
But as I was looking. Does your truck have an accelerator cable?? If not it will have an accelerator postion sensor. It is located at the gas pedal. It too might be dirty, not telling the Computer, "HEY HIS FOOTS OFF THE GAS".
Two rules in life.
Old 10-11-2008, 10:22 PM   #10
Kurt L
Kurt L's Avatar
Re: high idle.
thanks for the help i'll check it out tommorow.it seems to be getting worse lately also.thanks again.
Old 10-22-2008, 06:06 PM   #11
Damien
Damien's Avatar
Re: high idle.
You might also want to take the EGR valve off and clean it. The pintle will get a chunk of carbon stuck in it and iw won't close.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 10-22-2008, 09:33 PM   #12
Arad68
Trucks N Tranzams
Arad68's Avatar
Re: high idle.
Thanks Damien,
The books that I bought say that as well. My truck only has 19,500 miles on it, so I cant imagine the TPS being bad already. The people I bought it from didn't drive it much or very hard. I'm sure its carboned up as well.
Don
'56 Chevy 4WD SWB
95 Kia (Wifes car)
Old 10-22-2008, 09:59 PM   #13
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
Re: high idle.
Idle air sensor?
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
