Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 08-27-2008, 10:54 PM   #1
JayG
Formerly ADHDCARGUY
JayG's Avatar
Question Garage door opener question?
My garage door opener died. I am planning on replacing it with basically the same unit, again from Sears. My question is: the new openers all mention an anti-burglary feature that seems to indicate a rolling opening code. Can I disable this feature so I can still use my 4 existing opener remotes, that are the "learning" type or do I have to get new remotes? Thanks for the help!
Jay
67CHEVY SWB,355, built 700r, 5/7,9",posi 3.50,REAR BAGS,HOOSIERS, A/C.
54CHEVY - BURB, beginning construction(well, i gotta take it apart first!)
36FORD PU - WAITING
38CHEVY - 2DR SD,CHASSIS FINISHED
46CHEVY - BURB - waiting
JayG is offline   Reply With Quote
Old 08-28-2008, 06:39 AM   #2
Smoke-em
Smoke-em's Avatar
Re: Garage door opener question?
I recently replaced my opener as you are going to do. Bought one from sears that was a close to the original as I could get. It came with two remotes, and an outside mounted wireless remote.
Smoke-em is offline   Reply With Quote
Old 08-28-2008, 07:13 AM   #3
rambler
MOVE OVER
rambler's Avatar
sometimes if you get the same brand as before you can get lucky and "program" them to roll with the new unit. I would say yours may not be the case if it is pretty old, sears usually has good deals with multipule remotes, but charge too much just to add "one" more. I've been watching them waiting for my opening to finally die
No matter where you are..... There you are...
Buckaroo Banzi
rambler is offline   Reply With Quote
Old 08-28-2008, 08:16 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
As stated it will depend on the age of your opener. If it's an older unit before the remotes could "learn" then probably not. Do you really want to disable a feature that allows bad guys to roll down your street and open your door at will?
I suggest you check out Sams Club. I bought a Lift Master there with two remotes and a wireless keypad for the same as what Sears wanted.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-28-2008, 10:51 AM   #5
JayG
Formerly ADHDCARGUY
JayG's Avatar
Thanks guys! It was only about two years old or so. I'm thinking the "learning" remotes will operate with the newer unit. I'll let you know this weekend.
Jay
36FORD PU - WAITING
Old 08-28-2008, 01:00 PM   #6
ERASER5
ERASER5's Avatar
I had to replace my Sears opener due to a lightning strike a few years ago. My old opener was a non-rolling code, learning type unit. The new one was a rolling code learning unit. None of my older remotes would work with the newer rolling codes.
Hope this helps.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
