09-07-2008, 12:22 AM | #1 |
"Where were you in '62?"
Anyone have Tilt Front Ends and/Or Dump Beds?
Anyone of you fellas on here have Tilt Front Ends or Dump/Tilt Beds?
Post'em if ya have'em...... http://www.usbody.com/__Photo-Galler...y/62-001-b.htm http://www.usbody.com/__Photo-Galler...y/62-002-a.htm http://www.usbody.com/__Photo-Galler...y/62-004-e.htm
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
09-07-2008, 07:20 AM | #2 |
1961 crewcab
Re: Anyone have Tilt Front Ends and/Or Dump Beds?
I don't but I have some pics....
09-08-2008, 06:48 PM | #3 |
My Friend from Moriarty, New Mexico. 59' Apache, Pro Street, Tilt Front End, Dump Bed, 9" Narrow Rear End w/Weld Wheels, 29 x 15.5 Mickey Thompson's, Volare sub-frame, 350 cu. in., Weiand Tunnel Ram w/2-650 cfm Holleys, Suicide doors, custom dash.
09-09-2008, 12:52 PM | #4 |
Looks good Bud,
Once, I scene in Truck'in Magazine some where in the late 90's a feature of a yellow 63. It was called Sherman's March. It was pro/streeted, Blown, and had a Tilt Front and Dump bed. Looked Sweet. Thinking about Making my bed a Dump Tilt. I also want to put in Suicide Doors on her. Post'em if ya got'em Fellas........
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. Last edited by 1Bad62Pro/Street; 09-09-2008 at 05:36 PM. |
12-13-2009, 04:47 PM | #5 |
12-13-2009, 06:02 PM | #6 |
Got a tilt front end on the '62 Does the Peterbilt count???
top photo in with a chop top that we couldn't get a windshield for Can't believe I don't have one after I painted it but if you look close no seam bettween hood and cowl filler
62 GMC 910 short fleetside 454 super t10 14 bolt w/gov lock 70s c20 front discs (built in the 80s) 65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck) 63 GMC 950 camperized school bus, (Gus the bus) 350 4speed 2 speed rear 64 GMC 950 "spare" bus 283? 4speed detroit locker 53 GMC 1ton dual wheel bus 78 GMC c25 short course off road race truck(son's truck) 355 th400 14 bolt (www.wheel2wheel.ca) 88 Peterbilt 379 longhood (hauls race truck) |
12-18-2009, 12:45 PM | #7 |
I have this extended steel front. The hinge is made at the radiator support
area. For now, two people have to manually lift it and put two rods supports into the frame. I have a hydrolic power unit given me and two small cyls. Can anyone give me ideas on how to make something to lift this with???? My thinking so far is some type of rod under radiator/frame with some type levers on each end to cyls? Help! |
12-18-2009, 01:58 PM | #8 | |
If I were you and I didn't have the hydraulic equipment, I would consider using lift cylinders that you see on so many vans and SUV's to lift the rear hatch to assist lifting the hood. Just my take. But if you want to use the hydraulics, and you have both rams, I would mount the rams between the frame and core support. You'll have to do some geometry to get your desired lift in order to place the rams properly. Also, you may need to reinforce your hood and core support according ly with that hood being as long (and inherently heavy I suppose) as it is. That is just my $0.02. Last edited by rookierodbuilder; 12-18-2009 at 02:00 PM. |
12-18-2009, 03:18 PM | #9 |
Rollin' Old Skool
12-18-2009, 03:59 PM | #10 | |
12-19-2009, 09:01 AM | #11 | |
As far as the tilt mechanism you might want to consider electric actuators. These run off off of 12V volt power and IMHO are much cleaner to install than hydraulic systems. Here is a link to an install using this type of actuator. : http://www.clubfte.com/users/jniolon...gfulltilt.html You might have to use two of the actuators, just depends on the capacity of the actuators, the load it needs to lift, and how you install the mechanism to do the lifting. Some of these can lift up to 250 lbs!, Check out this link for a actuator source http://spideraccessories.stores.yaho...ocaulla12.html Last edited by lakeroadster; 12-19-2009 at 09:09 AM. |
12-19-2009, 01:25 PM | #12 |
You can see more of us V12'er at "702 GMC V-12 Powered 62 GMC 1-ton".
Thats in the 60-66 forum here. The pictures of mine start #445 page 18. I have another V12 in a stock 63 tilt cab with 23000 miles on it. Thats what gave me the idea to do this crazy 64. Lakeroadster, Thanks for the tilt front lift links. I agree, the electric looks plain and simpler. I do not know much about hydraulics. But the price was free for two complete units. Those hydro motors also take a big amp drain on the battery. Mybe I can find another use for them. |
12-19-2009, 04:26 PM | #13 |
1961 crewcab
I don't know about the wheels, but the caps look like 55/56 chevy truck original caps.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
12-19-2009, 06:43 PM | #14 |
12-20-2009, 05:06 PM | #15 |
Lakeroadster Try this link for those pictures. About half way down page.
http://www.hotrodhotline.com/feature...tml/page_3.php |
12-20-2009, 06:06 PM | #16 |
Junior Member
Rap'em Pappy:
Would a hydraulic set-up with two cylinders and a hand pump like on the tilt cabs work on the hood? Cayoterun
Cayoterun Okla. Panhandle I think I'll do it myself and pay the extra $500. |
12-21-2009, 08:22 AM | #17 |
Awesome tilt cab, thanks for posting the link.
12-21-2009, 10:34 AM | #18 |
Hollister, CA.
I have fabbed up many bed-lifts in my time. Late 80's thru the 90's was the fad on these mini-truck guys...
I always used a hydraulic pump (typically #4) and 8" to 10" cylinders to lift the bed. Came up with a tuck-a-way system that allowed the cylinders to swing out of the way. The traditional way was to have them pushing straight up, which allowed them to hang down, which ended up ripping the fitting off the bottom. This was back in the hard-copy pic days...will try and find some..
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
12-21-2009, 12:04 PM | #19 |
I have the tilt front end for my 59 project. Haven't worked on it in a year or so. I plan on using electric actuators. Maybe this spring I'll get on it again (now that my 60 is almost done).
1961 GMC Suburban Custom 1969 Short wide project http://67-72chevytrucks.com/vboard/s...d.php?t=535479 (SOLD) 1959 Apache fleetside (frame off in progress) http://67-72chevytrucks.com/vboard/s...d.php?t=348746 1960 Apache short/narrow shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=350780 (SOLD) 1951 Plymouth leadsled project 2005 Corvette conv. Procharged 1969 Corvette stingray 2006 Cadillac XLR-V 1950 Oldsmobile 98 custom project |
12-23-2009, 09:33 PM | #20 |
My 62 does it all.
12-24-2009, 07:48 AM | #21 |
this is a tilt hood hinge that I made myself, took a few trys to get it right.
it operates very smooth and puts my hood in the weeds Eric |
01-11-2012, 04:54 PM | #22 |
04-27-2012, 09:22 AM | #23 |
04-27-2012, 09:33 AM | #24 |
Senior Enthusiast
About 10 years ago there was a black show truck at Goodguys Spokane that had a tilt front and dump bed. All the trim on the truck was either brass or gold plated (I’m pretty sure it was gold). The trim wouldn't have been my first choice but it certainly was attention getting and really stood out. I had no camera with me that that year, and the truck never returned to the event. The owners were from Canada, so perhaps the trip was too long to make a repeat. I wish I had gotten some photos.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
04-27-2012, 12:50 PM | #25 |
Just have the forward opening hood, that I designed.
