09-10-2008, 09:06 PM | #1 |
Rocker and Front Pillar Question
I'm replacing my rocker panel and after taking my old one off I noticed that part of the front pillar was rusted and gone. I would really like to not replace this piece if it is not necessary so I was wondering if what is rusted out is needed for any support? Would I just be able to clean up what metal is left and POR-15 the remaining and put the new rocker on over?
09-10-2008, 09:18 PM | #2 |
Old Skool Club
Re: Rocker and Front Pillar Question
The configuration has to figure in structurally somehow. You can buy new stampings to replace the rusted-out sheet metal from Tri-Pro or other vendors. They will replace the rusted section from just below the hinge attachment and include the tab for the bottom of the front fender. If you have the expertise to replace the rockers, you should do fine with the bottom of the door posts.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
09-10-2008, 09:43 PM | #3 |
Firefighter
If you are planning on keeping the truck I would replace it or it will come back to Haunt you later, besides if you already have it this far apart it is pretty easy to fix it now instead of later!!!!!!
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA |
09-10-2008, 10:19 PM | #4 |
I'm a poor spectator
Absolutely, replace it now.
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! 1979 Ford F150 4x4 SWB Built Ford Tough!!! 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
09-11-2008, 04:13 AM | #5 |
It would be better to do it now, then regret not doing it later
1969 C/10 Longbed undergoing rebuild. Old Chevy's Never Die, They Just Rust Around The Edges |
09-11-2008, 11:47 AM | #6 |
Project Junkie! Fishing Poor!!
You definetly need to repair the pillar. It provides extra strength where the fender bolts to it. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
09-11-2008, 11:50 AM | #7 | |
PITbut
Cab pillar inside kick. inner rocker outer rocker. MAYBE the outside cab support also if its not to bad. I just fixed this on mine. If you havent done this before, it gets REALLY tricky when you replace all 4 of those things at once because you need them to all line up and still do their job.... |
09-11-2008, 07:08 PM | #8 |
Kick panel and inner rocker are all solid. Just the bump out piece is rusted. Anyone just fab a new piece for the bump out? Does the rocker get welded to that?
09-11-2008, 07:40 PM | #9 |
That part is very important since the floor ties in to it, the fender mounts to it, the inner and outer rocker ties into it. Here is a schematic of the structure.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
09-11-2008, 08:27 PM | #10 |
i have the same problem, but my entire kicker panel (was) rusted out all the way to the windshield(pics soon as im finished with repair).the patch parts are really cheap and if you have gotten this far you can do it
