Old 09-12-2008, 04:10 AM   #1
TimC63
TimC63's Avatar
Question Steering Column Question
I pulled the classic disassemble without notes or pics and now I'm a tard trying to put things back together...does anyone have a steering column schematic for 60-66 (assuming they're all the same)? Can't seem to find.
A couple washers, rings, or whatever there called fell off the steering wheel end of the column shaft and I need to know how they go back on. I know the one with the tab goes on first and I think the tab points downward towards the gear box side. I'd also kind of like to know what there purpose is as well.
Help!
Name:  Picture 007_1.jpg
Size:  66.6 KBName:  Picture 008_1.jpg
Name:  Picture 009_1.jpg
Size:  62.8 KBName:  Picture 0010_1.jpg
Wiring almost ready to go in!
TimC63
TimC63 is offline   Reply With Quote
Old 09-12-2008, 07:23 AM   #2
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: Steering Column Question
well they keep the shifter unit centered, for the life I can't remember which goes on top, they should slide over, and then spin /lock in place.
I was just messing with 2 columns a month ago, and it was a good 2 hour ordeal, I guess 60-61 are different than 63, and the parts do not interchange. that lock ring on the early column was what the turnsignal cupo was bolted to. but on the 63 the cup jus slid and locked on to the column
hmm I might have just confused it even more...
Old 07-21-2009, 09:51 PM   #3
daverod
SSN 706
daverod's Avatar
Did you ever figure out your steering column.I did the same thing. Now I'm wishing I would have taken some pictures.
daverod is offline   Reply With Quote
Old 07-22-2009, 05:30 AM   #4
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Hope this helps!
Old 07-22-2009, 09:03 AM   #5
daverod
SSN 706
daverod's Avatar
Thanks Aero I think I should have it put back together today. I was still having trouble with the horn part last night. Thanks for the pictures it helped clear up some other questions I had.
Old 07-22-2009, 09:49 AM   #6
dallas71
dallas71's Avatar
Awesome Stuff....Thanks DaveRod
dallas71 is offline   Reply With Quote
