Old 09-20-2008, 07:39 PM   #1
BIG CHEVY 3600
BIG CHEVY 3600 LONGBOX
BIG CHEVY 3600's Avatar
Question Why is this tranny leaking
700R4 and brand new never run.
I read on a website it would need 6 qts. to fill. I filled her and later noticed a big puddle underneath. It is dripping fluid out the tailshaft. I hope I just put too much fluid in it.
How many qts. does it take?????
_________________________
If I were given 8 hours to chop down a large tree, I would spend the first 6 hours sharpening my ax.
Abraham Lincoln
http://s729.photobucket.com/albums/w...cpZZ3QQtppZZ20
BIG CHEVY 3600 is offline   Reply With Quote
Old 09-20-2008, 08:43 PM   #2
AB6DO
Re: Why is this tranny leaking
The Bowtie Built 700R4 in my 1957 Nomad required 13 quarts to fill. My trans oil pan is a little deeper than factory. My 700R4 had a leak where the dip stick enters the trans body. I replace the leaky Lokar dip stick with a Gotta Show dip stick. Stopped about 95% of the drip.
AB6DO is offline   Reply With Quote
Old 09-20-2008, 09:09 PM   #3
OrrieG
OrrieG's Avatar
Is it dripping at the driveline? If it is "new" but has been sitting for a while the seal could shrink or deform a little. I've had some weep a little until they were ran for a while so they could heat up and seal. If it was just rebuilt it could have gotten damaged during install or when the driveline was installed.
OrrieG is offline   Reply With Quote
Old 09-20-2008, 09:22 PM   #4
BIG CHEVY 3600
If the seal has shrunk it should swell with the fluid soaked in. I'll check it in the AM and see if it is still dripping.
Abraham Lincoln
Old 09-21-2008, 12:55 PM   #5
OrrieG
OrrieG's Avatar
If you are lucky that is what happened. In the 80" I had a friend that found a 69 Porsche 911 that had been stored for 15 years with only 15K on the clock. He thought it was great to have a "new" car. Ended up tearing the whole thing apart to replace all the rubber, seals, belts, etc. that had dried out in our desert climate.
Old 09-21-2008, 05:12 PM   #6
entourageguy
Yellow truck club
entourageguy's Avatar
Is it in the truck?
Have you got a drive shaft in it?
If its in the truck have you run it to get fluid into the converter.
Maybe the trans is over full because no fluid has moved into the converter.
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 09-21-2008, 05:31 PM   #7
BIG CHEVY 3600
Brian
The driveshaft is new custom made and installed. I have not run the engine as it is a new crate 350 and I have not finished wiring and installing the radiator. I can see the drip is coming from a small hole in the center of the yoke. Can I plug this up and stop the drip.
Abraham Lincoln
