11-19-2002, 12:55 PM | #1 |
Gotta Startem Early
Clean Firewall Without the Master Cylinder?
Can a master cylinder from an older truck, one that mounts on the frame under the cab be used on on of our trucks? Does someone sell a kit for this type of conversion? That would really smooth out a firewall.
67 SWB In Progress, one piece at a time, maybe 3 years I will be finished |
11-19-2002, 01:07 PM | #2 |
Getting cabin fever?!?!?!
check out www.totalcostinvolved.com . they have a frame rail mounted master cylinder. haven't used it, but heard good things about them. they're power brakes but might take some doing to adapt to our trucks tho.
Member of the Discs Up Front Club 1972 GMC 1500 1994 F-150 XL 4x4 Tact is for people not whitty enough to be sarcastic Last edited by yellowgmc; 11-19-2002 at 01:10 PM. |
11-19-2002, 01:42 PM | #3 |
chevelito
turner enterprises has one in their ad. I sent them a letter for a catalog because the phone # was wrong. I'll let you know if I get one.
jay
New deadline...when my son can drive. Aloha from Honolulu, HI |
11-19-2002, 02:37 PM | #4 |
Gotta Startem Early
Does Turner Ent. have a web site?
11-19-2002, 03:14 PM | #5 |
chevelito
not yet.
jay
11-19-2002, 06:57 PM | #6 |
There are some special considerations for valving when you mount the master cylinder lower than the wheel cylinders. Check out www.mpbrakes.com for details.
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
11-19-2002, 08:47 PM | #7 |
frame mounting
make a cardoard cutout of the unit to check fitment under frame. exhaust can play a big factor when mounting as can shift rods.
you will need to add residual valves in the system to keep fluid from backing up. the aforementioned mpbrakes is a good place to start, great sit with plenty of info. oh, you will have to install a door in the floor of the pickup to access the master to fill it up. oh, you also gotta get a new brake pedal assembly too. good luck! Last edited by CustomChevy; 11-19-2002 at 08:49 PM. |
11-19-2002, 10:25 PM | #8 |
chevelito
hopefully the turner enterprise system will eliminate the work in figuring things out ....if the catalog ever comes in.
jay
