Old 11-19-2002, 07:15 PM   #1
BRIAN B
Question Gas Tank
CAN ANYONE TELL ME IF YOU CAN BY A KIT TO PUT THE GAS TANK UNDER THE BED ON A 68 GMC WITH LEAF SPRINGS.
BRIAN B is offline   Reply With Quote
Old 11-19-2002, 07:48 PM   #2
crazy longhorn
Fabricate till you "puke"
Yes, a blazer poly tank kit will fit. You will have a little fab work to set up the fill spout, but here is a link... http://www.classicheartbeat.com/cata...tank%20kit.htm
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 11-19-2002, 07:57 PM   #3
BRIAN B
THANKS FOR THE HELP. THIS MIGHT BE A DUMB QUESTION BUT WHERE DOES THE FILLER COME THROUGH.
Old 11-19-2002, 08:08 PM   #4
crazy longhorn
i have seen flip out sidemarkers, flipdown taillites, gas door welded to the side of the body......lots of innovative ideas! If you check classic heartbeat site, there should be pics on the side marker fill..... http://www.classicheartbeat.com/mark...t_gas_door.htm
Old 11-19-2002, 08:14 PM   #5
BRIAN B
WHAT DOES THE INSTALL LOOK LIKE. IS IT TUCKED UP UNDER THE BED WHERE IT IS NOT NOTICIBLE. I LIKE THE IDEA OF IT . I JUST HAVE NOT SEEN ONE INSTALLED.
Old 11-19-2002, 08:23 PM   #6
crazy longhorn
I havent installed 1 yet, but have been lookin at the kit pretty hard! From what I undersand , the tank hangs about 5-6" below the rails......does also stick up above the rails,requiring some trimming on 1 of the bed rails. Ill leave the details to the guys that have "been there" (dont want to steer you crooked!)....good luck......crazy man
