Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 09-29-2008, 10:27 PM   #1
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Fuel Pump relay in '94 S-10 Blazer?
I think my dads fuel pump went out. He wants to check the fuel pump relay before we do the pump. We already checked all the fuses they were good. Any other ideas? I am wondering where exactly we should look for the relay at? Thanks in advance
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 09-29-2008, 10:39 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Fuel Pump relay in '94 S-10 Blazer?
94 would be the first gen, or square body IIRC.... I'm 99% positive it's one of the two relays on the upper firewall close to the brake booster. (it has been 6 or 7 years since I messed with the relay on one)
BTW... have fun with that job. The connections that you need to get to on the fuel lines, are on top of the tank, and they are on hardlines.
Yeah... another one of GM's great ideas. They loaded the poS-10 with LOTS of great ideas.
Old 09-30-2008, 12:10 AM   #3
corn
'94 is actually a 2nd gen but Im not sure where the relay is. On my '96 its in the back of the glove box. Open the glove box & see if there is a removable cover in there. Going through the same thing on my '96 right now...
corn is offline   Reply With Quote
Old 09-30-2008, 07:20 AM   #4
truckdude239
truckdude239's Avatar
you could alway pull the bed off and get to the top of the tank thats way lol
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 09-30-2008, 08:11 AM   #5
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
its the fastest way to change them out there only like 10 bolts to undo the bed
i know at ford we were lifting the whole body off the frame to change heads on the excusion with the 5.4 l
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 09-30-2008, 10:37 AM   #6
fastwillie 696969
~Rest In Peace~
On your 1994 Chevrolet Truck S10 Blazer 2WD 4.3L CPI , the Relay - Fuel Pump is located:
Front seating area, driver side, driver side of steering column, behind instrument cluster, mounted in convenience center
for the fuel lines heres a tool dia.
Old 09-30-2008, 01:25 PM   #7
Hoods69BadBowTie
Chevys Kick A$$
What do you mean pull the bed off? its a Blazer. I know I can't wait to do it we are getting ready to go do it pretty soon. Wish me luck!
-LATER
Old 09-30-2008, 04:45 PM   #8
Longhorn Man
the first gen for s-10 pick up was 82 - 93.... the first gen for s-10 Blazer was 83 - 94
Old 09-30-2008, 04:52 PM   #9
corn
Yep, I was one of the others that missed the "Blazer" part too. My bad...
Old 11-29-2009, 10:37 PM   #10
narftroz
Relay is on the left then the horn then the fog lights on the right (if equipped)
hope that helps.
narftroz is offline   Reply With Quote
Old 02-13-2010, 11:41 AM   #11
70BLAZERX2
The fuel pump relay is mounted under the hood,just to the right above the brake booster...there are 2 the same side by side,you can try switching them to test if it will work,It may be the pump itseld and you have to drop the tank to change that.
One more thing to check,if you have an oil leak at the oil pressure switch located by the distributor,this can cause the fuel pump not to run, All gm injected motors have a run safe built in,if oil pressure drops below 7 psi,it will shut down the fuel must circuit.
I have worked on these 92-95 CPI blazers for years...I just biult a 93 S10 with the 4.3 "W" motor in is, see pics of 93 S10 Vortec Build "w" on here.
Take a block of wood and smack the bottom of fuel tank, then listen to see if the pump runs then,if it does change the pump. And dont go aftermarket with the CPI pump, go a/c delco..unless you want low power and have to do it twice,the aftermarket pumps are universal , this needs 67 psi to open the injector up..Done to many and know its no fun to drop the tank 1 time let alone 2 ,3 ,4 you get it...
70BLAZERX2 is offline   Reply With Quote
Old 02-13-2010, 11:24 PM   #12
drivewaycustoms
drivewaycustoms's Avatar
^^^this guy is 100% correct. I've had to put a fuelpump in almost every blazer that I've had (7) and it is a real pain.
87 Crewcab Dually
66 Cadillac Sedan deVille
55 Chevy Belair
33 Plymouth sedan
03 S-10
86 S-10 Blazer
IG drivewaycustoms
drivewaycustoms is offline   Reply With Quote
