brake help
i have four wheel disc on my truck i have a booster master cylinder and combination valve off of a mid 90s chevy truck. seems like rear brakes drag pedal is spongy bleed several times. i read on mp brakes site that disc/drum master cylinders have built in residual valves that will cause rear brakes to drag in disc disc situation.
i wanna go back to manual brakes so i need a master cylinder for manual brakes and 4 wheel disc. anyone know of something i can use from auto parts store. would rather not have to order one right now but if thats my only option what would be a good one. thanks |
Re: brake help
compare a 99 to 2003 master cylinder. They have 4 wheel disc.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
Re: brake help
i found 76 corvette manual disc/disc brakes. will look into that though the one for the vette is only 30 bucks though
Re: brake help
the vette one may come closer to a direct swap.
Re: brake help
I put a vette manual disc master on my old 72 with 4 wheel disc. It's now Outlaw72's truck. Orange and white.
Re: brake help
do u have to run a combination valve when running 4 wheel disc ive seen alot of pics of cars and i don't see any. i see the adjustable proportiong valve is that the same thing
