Old 10-07-2008, 01:10 PM   #1
67mater
67mater's Avatar
67 K20 closed knuckle drop pitman arm
Don't want to cough up the cash to go to open knuckle and crossover steering, so anybody know of a drop pitman arm for a 4 stud closed knuckle 67 Dana44 front axle? How hard is to get the one I have bent? Also, why are drop drag links $100+???? can't I get threaded rod bent??
time is inversely proportional to money; that's why it takes me so long
1967 K10
1967 Camaro
67mater is offline   Reply With Quote
Old 10-07-2008, 02:19 PM   #2
earl87gta
earl87gta's Avatar
Re: 67 K20 closed knuckle drop pitman arm
are you sure you need it? My 68 turns fine with a 6in lift and 36 in tires just incase there is a diffrenc in our steering set ups yyou can check out this thred from the last time i rember this cming up it has pics and mesrment off my burb.
http://67-72chevytrucks.com/vboard/s...d.php?t=217772
I hope it helps.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 10-07-2008, 02:27 PM   #3
OLDCHEV4X4
OLDCHEV4X4's Avatar
The pitman arm is on the steering box.
The steering arm is attached to the knuckle.
So you want a steering arm?
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 10-07-2008, 02:29 PM   #4
67mater
67mater's Avatar
well, my knuckle top looks different than yours. my 4 bolts are not in a pertfect square. the outer two are closer. Having said that, I don't think I have enough lift to require both, but with my new DIY4X leaf plates, my existing pitman arm is too close. That's why I think I can do a dropped pitman arm. Problem is the odd knuckle top/closed knuckle thing. My lift is in the 4" range, so I think the orginal drag link would work, just commenting on what I saw of what others did with a drop one.
There's a pic in my build thread of how close the pitman arm is to the leaf plate. I figured a 2" rise in that would clear the plate and improve the angle of the joints. Anybody know a shop that fabricates dropped pitman arms that would be able to drill for my bolt pattern? or is there any chance of heating up the factory arm and puttign an S in it? even an inch would solve the clearance issue.
1967 K10
1967 Camaro
Old 10-07-2008, 02:36 PM   #5
67mater
67mater's Avatar
ok, sorry, meant steering arm. The arm that bolts tot he knuckle is what I need raised, at minimum for clearance, potentially to correctthe lift at the same time
1967 K10
1967 Camaro
Old 10-07-2008, 05:09 PM   #6
Yukon Jack
Post Whore
Yukon Jack's Avatar
When I lifted my 69 K20 with the closed knuckle Dana 44, the only steering correction I could find was an adjustable drop drag link. It was from Skyjacker or Superlift.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 10-07-2008, 05:13 PM   #7
67mater
67mater's Avatar
Well, I could clearance the leaf plate. yukon jack, how is the angle of the joints? looks like a bit high, especially as you turn right. I'm gonna see if I can get a drop steering arm made (since I clearance issues) but maybe a drop pitman arm would be easier?
1967 K10
1967 Camaro
Old 10-08-2008, 08:07 AM   #8
OLDCHEV4X4
OLDCHEV4X4's Avatar
Would it be possable to make a spacer to go inbetween the steering arm and the knuckle?
It wouldn't hold up to hard wheeling, but it would work for light duty stuff.
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
Old 10-08-2008, 09:47 AM   #9
67mater
67mater's Avatar
strength would be my concern. the steering arm is held largly by the friction against the knuckle, and a spacer makes for 4 surfaces taht must bind, plus I would get .5" tops before I'd be out of stud.
1967 K10
1967 Camaro
Old 10-08-2008, 12:52 PM   #10
padresag
you don't want to drop the pitman arm as that will change the ratio of your steering (turns of steering wheel). just buy one of those dropped d/links as ugly as they look.
I would just notch out that spring plate for clearance.
the steering arm(off top of knuckle) on my old frt end was heated by the look of it and bent a litlle and then they welded plate to it top and bottom; for strength I suppose(i can get you a pic if you like). If you bend it to much, again you are going to affect the steering ratio(shortening the distance between the d/link and knuckle). you would be better of fabricating a new steering arm or sending the old one off to someone qualified to modify it(like the guys that do dropped axles).
it is a terrible think to have brake when you are travelling down the road,and I hope that iy is not me going in the opposite direction when it breaks
ron
it looks like you cut off the old ball stud. when you put it back together just ream out the lhole(taper) to accept a t/rod type end as found on newer d/links. same as for your pitman arm, this will allow you for a bit more flexability there
padresag is offline   Reply With Quote
Old 10-08-2008, 12:57 PM   #11
67mater
67mater's Avatar
you're confirming what I think may have to happen. the drop link should make up the lift I have and I'll just trim the plate backa bit. Looking at it last night, however, the steering arm bends down toward the axle a bit; it may be bent in the wrong direction as is.
1967 K10
1967 Camaro
Old 10-08-2008, 04:07 PM   #12
Yukon Jack
Post Whore
Yukon Jack's Avatar
I think the angles are fine - never had any binding.
Old 10-20-2008, 11:07 PM   #13
glimmertwin01
glimmertwin01's Avatar
and I thought my 67 was rusty and beat up.... NICE job man! you are making me want to get to work.on it... ust bought a salamander winter is coming.... at least i wont freeze!
67/68 K/20 "The BEAST"
68 K15 V6 LWB.
73 K20 GMC Burb "The Bomber"
74 K/5
74 K20 Custom Deluxe
86 K10 Shorty
92 K2500 Burb
95 K2500 GMC
Life is what you make it Live each day like it was your last
Old GM Trucks never go out of style
glimmertwin01 is offline   Reply With Quote
Old 09-29-2009, 01:48 AM   #14
petty
got installed a drop pitman arm last weekend. it just fitted all GM 4Wd power steering boxes from about 67 to 91 solid axle vehicles.
petty is offline   Reply With Quote
Old 09-29-2009, 05:53 AM   #15
j.kirn
A machinist can do anything
j.kirn is offline   Reply With Quote
Old 07-01-2019, 05:50 AM   #16
gmc 2500 4x4
subscribed
gmc 2500 4x4 is offline   Reply With Quote
Old 07-01-2019, 02:20 PM   #17
padresag
Depends on the machinist and his equipment Joe
