Old 10-12-2008, 07:20 AM   #1
wig
z-ing my frame
I want to z my frame on a 67 suburban.I tried using search first couldn't find anything. what I'm trying ti find out is if I z the front.Am I gonna have to cut the floor for the trans.thanks for the help.
wig is offline   Reply With Quote
Old 10-12-2008, 11:47 AM   #2
hotrodhomi
hotrodhomi's Avatar
Re: z-ing my frame
how big is the Z?
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 10-12-2008, 11:56 AM   #3
newagecustom
c10 Chop Artist
newagecustom's Avatar
Re: z-ing my frame
It also depends on which transmission tunnel you have (3 spd or 4 spd).
newagecustom is offline   Reply With Quote
Old 10-12-2008, 07:39 PM   #4
wig
Re: z-ing my frame
I think its 3 speed.how much more room will a 4x4 hump give me.so I can put as much of a z as I can.
Old 10-12-2008, 10:11 PM   #5
newagecustom
c10 Chop Artist
Re: z-ing my frame
A 4spd hump will give you more room. you only need to do about a 2 inch Z to lay the truck flat if you are going to bag it. You should be able to do a 2 inch with a 4spd hump, no problem. But you will have to make a tunnel for the driveshaft.
Old 10-12-2008, 10:50 PM   #6
leftcoast66
leftcoast66's Avatar
Re: z-ing my frame
Or use the 2 piece driveshaft should help with the driveshaft issues.
leftcoast66 is offline   Reply With Quote
Old 10-13-2008, 05:24 PM   #7
wig
Re: z-ing my frame
it has a 2 piece.I gonna need a hump then.as far as the tunnel I guess I'll play that by ear.
Old 10-13-2008, 06:01 PM   #8
RunninLo
3DrDwn--the 'burb not the band
RunninLo's Avatar
Re: z-ing my frame
I have a 72 burb with a 2" raised x-member( I know not a z but since the questions are driveshaft/trans hump related)
I had the low hump and had to cut out for my trans. My driveline is super close to the floor and may now need a tunnel. It didn't before I removed the body but it was close enough to make me consider one. I'll know more once I put the tub back on. I removed the body to work on the rear notch/4link.
Josh
Slo and Lo that is the tempo.
'72 burb build page here:
http://67-72chevytrucks.com/vboard/s...d.php?t=259256
'89 GMC Dually crew build page coming soon.
88 4x4 crew DD
duallys past/present pics here:
http://67-72chevytrucks.com/vboard/s...46#post4001246
89 1 ton Dually rear flip kit install here:
http://67-72chevytrucks.com/vboard/s...d.php?t=354327
RunninLo is offline   Reply With Quote
