10-12-2008, 12:49 PM | #1 |
Junior Member
Vortec crate motor?
Anyone using GM part number 12530282 replacement engine for 96-02 trucks? It looks like it would work well in one of our trucks. I know the vortecs need a special intake, but what about the water pump, distributer, fuel pump, etc. They are about $2,200 from Scoggin-Dickey.
63 C10 70 Coronet R/T 67 C10 70 Dart Swinger 71 K10 |
10-12-2008, 02:54 PM | #2 |
Old Skool Club
Re: Vortec crate motor?
They don't have provisions for a fuel pump. You'd have to use an aftermarket electric fuel pump. Beyond that, my brain just died.....or farted....whichever makes the thought process go away.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. Last edited by ChevLoRay; 10-12-2008 at 02:55 PM. |
10-12-2008, 03:31 PM | #3 |
Between Trucks...
http://store.summitracing.com/partde...530282&FROM=MG
I was thinking about that motor for my '69. Anybody know if it would run on 87 octane?
Beat it to fit, Paint it to match... |
10-12-2008, 03:43 PM | #4 |
I am running a 350 w/Vortec heads. GM part #12496968 Its fairly priced around $3500-3700 depending on how much you haggle the dealer. Its rated at 330 HP/380 ft.lbs torque. It has HEI distributor, intake, Holley 600 carb, plug wires. Just add alternator,fuel pump,mini starter, headers, or manifolds, and shes ready to fire. They also sell it in a turnkey version for around $4500 or so. I like the motor myself.
72 C20 Longbed 05 1500 Z71 |
10-12-2008, 03:51 PM | #5 | |
Between Trucks...
10-12-2008, 06:25 PM | #6 |
Junior Member
The photo on the Summit page looks like there are provisions for a fuel pump. Does the roller cam use a different dist. gear?
10-12-2008, 07:44 PM | #7 |
i thought they just had a block off plate where the fuel pump goes, unless the cam doesn't have a lobe for that, i don't see how you couldn't run a manual pump.
10-12-2008, 07:47 PM | #8 |
Weekend Warrior
Usually the boss for the fuel pump is there, but the hole for the push rod is not machined. This is common with the early 90's TBI motors as well.
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered |
10-13-2008, 02:22 PM | #9 |
10-13-2008, 02:38 PM | #10 |
Here is the info for the vortec crate motor I got
I pump Chevron 91 Octane in it She really likes it ! ___________________ Dimensions Engine ___________________ PACE Super Stores LSx Performance Truck & SUV ___________________ Gift Cards ___________________ Company Store Hours & Address ___________________ Policies Engine Warranty Policy Privacy Policy Shipping Policy Return Policy ___________________ Email PACE Web Sales Email Tech Questions Email Webmaster ___________________ Links Recommended Links Vendor Links GM Performance Parts 12496968 Email this to a friend 12496968 - 330/350 HO Deluxe 12496968NoLift Pace Price Qty $3,889.95 Product Options Lift Gate Required? No Yes [ADD $100.00] Detailed Description The 350 HO Deluxe takes the value leading 350HO/330HP Crate Engine a step further by adding carburetor, distributor, water pump, torsional damper, and auto trans flexplate. This enhancement to the Vortec headed 350HO makes it easier than ever to repower your street rod, street machine or sportsman racer. The 600 cfm vacuum secondary Holley carburetor is ideally suited to the 350HO. And the proven GM HEI distributor will give years of worry-free driving. With a 9.1:1 compression ratio, it's pump gas friendly, and with its muscle car idle it's cruise night cool. With GM Performance Part's lowest priced small-block crate engine there is no reason to rebuild that junk yard clunker and since it's complete from carb-to-pan there is no need to chase parts ! The 350 HO is not intended for marine use, and should only be used in 1973 and earlier pre-emissions street vehicles or any year off road vehicles. < Engine specs: *Horespower- 330 @ 5000 rpm *Torque-380 Ft Lbs @ 3800 RPM Max. Reccomended RPM 5500 Compression Ratio- 9.1:1 Parts Used in this engine assembly: Block- 4 Bolt main, Part # 10105123 w/ 1 piece Rear main seal -------------------------------------------------------------------------------- Crankshaft-Nodular cast Iron Part# 14088527 -------------------------------------------------------------------------------- Connecting Rods-Powdered Metal-part # 10108688 -------------------------------------------------------------------------------- Pistons- Dished, Cast Aluminum- part # 12361371 -------------------------------------------------------------------------------- Camshaft- Hydraulic flat tappet- part # 24502476 Specs- Intake lift- .435",Exhaust Lift- .460". Intake Duration @ .050"-212,Exhaust duration @ .050" 222, Lobe Centerline 112.5 -------------------------------------------------------------------------------- Timing chain- Standard morse link- Part # 14087014, crank gear- part # 10128346, cam gear part # 12552128 -------------------------------------------------------------------------------- Cylinder Head- part # 12558060 Vortec Cast iron- 64cc Chambers,170cc intake runner, 1.94" Intake valve, 1.50" Exhaust Valve -------------------------------------------------------------------------------- Rocker Arms-part # 10089648 Stamped Steel , self aligning, 1.5:1 ratio -------------------------------------------------------------------------------- Carburator- part # 12497147 Holley 600 CFM Vacuum secondary w/ electric choke -------------------------------------------------------------------------------- Intake Manifold-12496820 Dual plane with EGR capability- (extra parts required to connect EGR) Extra parts required to connect EGR-10220275,12552329,17113433,ED2899- See links Below if these parts are needed. -------------------------------------------------------------------------------- Spark Plugs- AC Delco R42LTS Gapped @ .045 -Timing is 10 BTDC at idle. -------------------------------------------------------------------------------- Distributor- HEI Part # 88961867 Advance Curve: Mechanical Vacuum 1100 RPM-0.0 3.00 (in.hg.) 0.0 Timing Should be Set @ 32 Total @ 4000 RPM 1600 RPM-12.0 7.50 9in.hg.) 20.0 With Vacuum Advance Disconected.Vacuum 2400 RPM-16.0 Advance should be connected to a ported source 4600 RPM-22.0 at the carburator. -------------------------------------------------------------------------------- Plug Wires-12368383 Gm Performance parts Red silicone jacket spiral core wire, high temp boots. -------------------------------------------------------------------------------- Water Pump-Part # 88894341 Cast Iron Long style with standard "V" belt rotation Threaded for 79'-86' P.S. Pump bracket -------------------------------------------------------------------------------- Balancer-Standard 8" For use w/ 2:00 Timing pointer -------------------------------------------------------------------------------- Flexplate -part # 14088765- 12 3/4" Automatic -------------------------------------------------------------------------------- Air Cleaner- 14"x3" with chrome lid -------------------------------------------------------------------------------- Thermostat- 180 with standard cast aluminum housing with driver side hose connection -------------------------------------------------------------------------------- Also Includes : oil filter, oil filter adapter ,pcv valve, pcv hose ,oil dipstick and tube. Does not include Starter, Fuel pump,fuel pump pushrod, fuel pump adapte Feedback - Terms of Use - Contact Pace Performance Copyright 2008 by Jim Pace Pontiac Inc. dba Pace Performance Need Help? 1-888-748-4655
10-13-2008, 06:38 PM | #11 |
Between Trucks...
Sleepertruck72 sounds nice, but that's a different motor then the OP is talking about.
10-13-2008, 08:33 PM | #12 |
Junior Member
Yea, the motor I'm looking is a little different than the H.O. 350. The one I'm looking at has a different cam and a little more compression.
10-14-2008, 12:35 AM | #13 |
Just my 2 cents on the vortec options
10-14-2008, 11:22 PM | #14 |
Junior Member
I researched a little more. The H.O. is also a four bolt block. The long block version of the H.O. is about $500.00 more than the other motor. I guess I have a little more to think about.
10-15-2008, 01:16 AM | #15 |
What if you take a pre 96 or even pre 87 use Vortec heads on a older style short block? With the appropriate intake and decent cam, of course. Basically same thing for a lot less money.
79 Blazer Cheyenne, 2wd 305 3.42 stock 85 Caprice, TBI converted, new 350 crate motor, Monte Carlo SS Wheels, Bilstein shocks, |
10-15-2008, 01:12 PM | #16 |
Great idea if you have an existing short block in good shape, but you would still not have a roller cam (eliminates all of the problems of running a flat tappet, non roller high lift cam with the modern oil with no zinc) If someone is starting from scratch, I advise going with the Vortec style engine.
10-15-2008, 01:47 PM | #17 |
The 86 and up SBC 350 all had provisions for a roller cam so if you can find an 86 up block you could build this motor (a lot better I may add). If you stick with a 86 to about 92 block it should have a mechanical fuel pump capability. If building a motor is beyond your ability, then a crate is the way to go IMO. They also sell an HT383 for 350 replacement in the 96 and up chevy trucks, that would work in an older non-efi application as well.
I personally bought two Vortec 350's for cores and made one a wicked 383 and the other was clean and nice I was able to rering it and put a bigger cam in it with the heads being completely rebuilt and the springs can hang with .600 lift, but only run about .500 lift, so my little rock stocker (sorta) 350 Vortec should scream and the 383, well, that will be a monster. good luck! |
10-15-2008, 05:02 PM | #18 |
i bought a new vortec for my 99 suburban this spring. the block isnt fully machined. the mounting face is there, but there is no hole in the block for the fuel rod. my original engine i pulled out has the block fullly machined for the use of a mechanical pump. they just inserted a plug in the hole.
72 chevy 3\4 ton 4 speed 4x4 84 1\2 ton 4x4 (gone but not forgotten, thanks for the memories) 1999 suburban 4x4 1982 chevrolet S-10 V-8 (Thanks uncle EARL) |
10-15-2008, 08:14 PM | #19 |
Junior Member
I was thinking about finding a late model core and having it rebuilt to my specs. I just found this motor on the internet and it seemed like a compromise between rebuilding and the H.O. I think I'll keep looking for a good core and if I can't find one for cheap, I'll look at crate motors again.
10-18-2008, 10:45 AM | #20 |
Junior Member
So, if I understand correctly, the hydraulic roller cam doesn't have a lobe for a fuel pump. Even if the block is machined for a mech. fuel pump I'd still have to use a elec. pump. The H.O. uses a flat tappet cam. Decisions desicions......
10-18-2008, 12:09 PM | #21 |
electric inline pumps can be had cheap, if your running a carb you can get a pump for 100$, then get a regulater to put the pressure at the psi you need. there is to many advantages to a roller cam over the flat tappet. dont let the fuel pump be the deciding factor on what engine you buy or build.
10-18-2008, 02:48 PM | #22 |
Junior Member
That's what I'm thinking. The benefits of the roller cam are way more than the cost of an elec. fuel pump.
10-18-2008, 03:03 PM | #23 | |
http://www.picturetrail.com/fregon |
10-18-2008, 04:35 PM | #24 |
i seen in jegs mag they have a carter pump for 70$ that puts 5-6 psi, and they have 1 that is 6-8 psi for 80$. those should work fine with a carb.
10-18-2008, 05:38 PM | #25 |
that is what I have, the cheap carter. Been working fine for 3 years now.
