Old 11-22-2002, 10:11 AM   #1
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Torque Settings for Tie Rods etc.
Hey guys I need a little help with some torque settings. I hope to have a rolling chassis by sometime tomorrow. I just have a few items left to set and torque.
Would someone please let me know what the torque settings are for the tie rods, pitman arm (to link bar),and idler arm (to link bar)?
Also, you guys that have done a full front end rebuild answer me this. I have torqued the spindles/ball joints and rotors to specified ft lbs and it seems like nothing wants to move. The rotors are very hard to turn and it take a whole bunch of grunt to turn the spindles. Is all of this normal because it is new and tight? I suppose it will loosen up as it goes. I just don't want to ruin bearings or have the steering pump give out on the first try.
As always thanks for your help. I will post some pics of the chassis on her feet when it is done.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 11-22-2002, 11:16 AM   #2
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Well according to your signature you have a 71 1/2 ton so this is what the specs are for that.
1.) Pitman arm to relay rod - 60 ft. lbs.
2.) Idler arm to relay ros - 60 ft. lbs.
3.) Idler arm mounting bolts - 30 ft. lbs.
4.) Tie rod Ball joint nut (outer and inner) - 35 ft. lbs. (plus torque required to align cotter pin, not to exceed 50 ft. lbs. Max)
5.) Tie rod clamp bolt - 22 ft. lbs.
6.) Steering connecting rod nuts - 50 ft. lbs. (plus next slot in nut to align cotter pin)
7.) Steering Gear mounting Bolts - 65 ft. lbs.
Hope this helps.... WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 11-22-2002, 11:23 AM   #3
1971Stepside
Almost Satisfied
Thanks Wes. I'm drawing a blank on number 6....which one(s) is that? Maybe it is too early.
How about the overall stiffness? Is that normal? I know if I torque the Pitman and Idler to 60 ft lbs she ain't gonna want to move.
Old 11-22-2002, 11:24 AM   #4
72MARIO
72MARIO's Avatar
Hey I guess Wes covered the torque spec stuff as for the tight feeling as soon a I greased my front end susp parts everything turned alot easier . But for the rotors the touque spec is 12 foot pounds and the should spin easy . Good luck
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 11-22-2002, 11:27 AM   #5
72MARIO
72MARIO's Avatar
I have no idea what 6 is refering to ?
2005 TAHOE DD
Old 11-22-2002, 11:27 AM   #6
1971Stepside
Almost Satisfied
12 on the rotors??? Early Classics web site said 15. Hmmmmm....I'll check that out and grease the snot out of everything and see what happens.
Old 11-22-2002, 11:31 AM   #7
72MARIO
72MARIO's Avatar
Yah i saw ther epage and it said 15 but I looked in the haynes manual and it said 12 . 15 was way too tight for me becaUSE the bearing shopuld to spin with no friction
Oh you will need a crap load of grease I used omost 2 tubes.
2005 TAHOE DD
Old 11-22-2002, 11:39 AM   #8
1971Stepside
Almost Satisfied
72Mario...thanks for the help. Did you grease everything before you torqued it or after?
Old 11-22-2002, 11:46 AM   #9
72MARIO
72MARIO's Avatar
I greased everything after just made cents ! well if i converted it into US funds I would be breaking the pennies in half .
2005 TAHOE DD
Old 11-22-2002, 11:49 AM   #10
Classic Heartbeat
The connecting rod is the rod that connects the two sides together and and also connects to the pitman arm. The book calls it a relay rod where it connects to the pitman arm and a connecting rod where it connects the two sides.... Also on the front wheel bearings... When I adjust them by spinning the wheel and when the torque starts slowing it down then I back off the nut about 1/4 turn, then align it for the cotter pin with the next slot toward loosening it. WES www.ClassicHeartbeat.com
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 11-22-2002, 11:51 AM   #11
sniper2321
sniper2321's Avatar
when you grease the joint 's go with a synt. grease and only let the grease go till the inatial expansion of the joint boot's if the grease comes out you will have it go everwhere and it will be a big mess hope that help and the torque for the bearings for disk should be 12 with the wheel on for weightwhen you spin the wheel to get the grease to spread out on to the spindel pin.
sniper2321 is offline   Reply With Quote
Old 11-22-2002, 12:04 PM   #12
1971Stepside
Almost Satisfied
OK, WES....I think I got it. How many names can there be for one part. LOL
I tried that on my rotors and when I put the tires on I could wiggle the whole rotor so I know it is too loose. I will work on it tonight and if I get stuck I will post back. Thanks again.
