10-16-2008, 11:34 PM | #1 |
Bloo
any interest? 2003 5.3L tahoe flex-fuel parts
2003 (i believe) complete underhood engine wiring harness, only wire that was cut is one battery cable
fuel rail with injectors plastic intake with MAP sensor and EVAP purge solenoid electronic accelerator throttle body also including the oil PSI sender as far as i know this is NOT from a vin T 5.3. i believe it to be a Z, but i have no way of proving as the engine was already pulled when i got it. these are leftover parts from putting a 03 tahoe engine in a 02 K1500 looking to get $200 plus shipping. $200 wouldnt even put a drop in the bucket towards these parts at a dealer. parts have around 68000 miles on them thanks! Josh |
10-25-2008, 09:30 PM | #2 |
Re: any interest? 2003 5.3L tahoe flex-fuel parts
i wonder if i can use these parts on a 2000 ? would i still need the ecu ?
1986 chevy c10 in the "build" process as we speak 358 flat tops, vortec heads, .500 lift cam, NOS power shot plate system, yada yada yada MMA PIX http://www.clgpix.com/MMA/Fighters/F...C/CoteTony.htm MMA RECORD 24-5 |
10-25-2008, 11:43 PM | #3 | |
Bloo
im not really sure, but i'll see if i can find out. are you wanting to flex-fuel your 2000?
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
