ls2 or ls3
I am looking at crate engines for my c10, Iv'e decied I want a aluminum block ls engine. I have found 2 that I like but the price is about $3000 different by the time I by all the ingniton contols. I dont really plan on taking the truck to the strip alot and I dont plan on taking it on long drives. It will be just something fun to cruise around on the street and take to the strip every now and then, it wont get driven in the winter, late fall and early spring and rarely in the rain. In the near future I thought about bring the hp up to about 550hp with a centrifical super charger. I've not really decided on the trans either it will either be a th-350 or a 700r4. I realize that these 2 engine and trans combo's are completely diffrent but let me know what you guys think here's the stats of the engines:
Horsepower: 446 @ 6200 rpm Torque: 412 @5000 rpm Compression Ratio: 10.9:1 Block: Cast Aluminum 6-Bolt Crankshaft: Nodualr Iron Heads, Chamber Size: Aluminum, Symetrical Port Valves (I/E): 2.000"/1.550" Camshaft, Lift (I/E): 0.500"/ 0.500" , Hydraulic roller Camshaft Duration @ 0.050" I/E: 200/203 degrees Intake Manifold: LS1 4-barrel Part #17802134Price: $5,095.00 Based on the LS2 engine, the LS 364/440 ships with an aluminum LS block, which has a deep-skirt and six-bolt mains. Other features include light weight flat-top pistons with a 10.9:1 compression, powdered-metal rods, and a nodular iron crankshaft. The LS6-style cylinder heads are truly high performance pieces that deliver large amounts of air to the awaiting engine. The camshaft specs out with .500/.500-inch lift numbers, and has been specifically designed to work with the LS Family. • 14-in automatic transmission flexplate included • Requires aftermarket spark controller compatible with the 58X reluctor wheel and new cam sensing • Intended for pre-1977 street vehicles and all off-road vehicles or GM Performance 19171224 - GM Performance Parts fuel injected 376CID/480HP LS3 Engine Details Block (P/N 809-12584727): Cast Aluminum with 6-bolt, cross-bolted main caps Bore x Stroke (in): 4.06 x 3.62 (103.25 x 92mm) Camshaft duration (@.050 in): 219 degree intake / 228 degree exhaust Camshaft type (P/N 809-88958733): Hydraulic roller Compression ratio: 10.7:1 Connecting rods (P/N 809-12617570): Powdered metal Crankshaft (P/N 809-12597569): Powdered metal Cylinder heads (P/N 809-12598594): LS3 rectangle port; as cast with 68cc chambers Displacement (cu in): 376 cu in (6.2L) Engine type: LS Series Gen IV small-block V8 Maximum recommended RPM: 6600 Part number: 809-19171224 Pistons (P/N 809-19165089): Hypereutectic aluminum Recommended fuel: 92 octane Reluctor wheel: 58x Rocker arm ratio: 1.7:1 Rocker arms (P/N 809-12569167 int): Investment cast, roller trunnion Valve lift (in): .525" intake / .525" exhaust Balanced: Internal Valve size (in): 2.16 int / 1.59 exhaust for $6895.99 w/o emc which is another $1000
1970 c20 converted to c10 sleeper 1979 c20 the wood hauler 1991 honda civic daily driver spray and pray baby Last edited by GMC70c20; 10-28-2008 at 02:16 AM. |
On a budget like Fred Sanford
Re: ls2 or ls3
For what you're wanting out of it, the LS2 would suit you just fine. Take some of the extra money you'd spend on the LS3 and install a better cam.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
Re: ls2 or ls3
Agreed.. The $3k you saved going with an LS2, you could find a set of used ported LS1/6 heads and a medium cam and be putting down some decent power.
Any reason you would want to use the TH350 or 700 over a 4L80E? The 80E has many of benifits like being super strong, electronic control through the PCM for shift points, lock up TQ converter for even better mileage.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
Re: ls2 or ls3
i have a well built th-350 just sitting in my garage, I also figured for how much I'm going to drive it a little worse fuel economy wont hurt anything.
1970 c20 converted to c10 sleeper 1979 c20 the wood hauler 1991 honda civic daily driver spray and pray baby |
Re: ls2 or ls3
I'm looking at the same swap as you c20. Just pricing the parts out to build a 408 with the block I already have and I'm way more money than the LS2. The way I see it, I would really have to want a 408 because the LS2 makes more financial sense. The LS3 and the 408 would be similarly priced, but the LS3 would make more power. I'm leaning more towards the LS2 and put a cam in it for sound effects.
What headers are you planning on using?
Stu- 1981 GMC Sierra Classic LWB 355- original 2 bolt block, 10.2:1, vortec heads, Comp XE268 cam, built by self in 1992 700R4-2000 stall with lockup, shift kit, Corvette servo 3.07 open diff- I need a 3.73 posi! 2nd owner since 1986 - 388,000 km and counting. 100k by the first owner and the rest by me. |
Re: ls2 or ls3
L92's
Re: ls2 or ls3
I'm wanting long tubes so I'd probably wait for Doug's. But this project is going to be a while so I have time.
Found this online http://paceperformance.com/index.asp...&ProdID=225248 and that looks real interesting to me.
Re: ls2 or ls3
You guys can probaably make a set of 98-02 F-bod Edelbrock Super Vic headers to work. They fit in my truck. I'm running the 1 3/4" stepped to 1 7/8 with high velocity merge collectors. the nice thing about them, since they are a slip fit collector, you can pull the collector off and put a piece of 1 3/4" pipe in the ends of the tube ans move them some if need be. Then slide the collector back on..
