11-04-2008, 03:42 PM | #1 |
Old Shovel Rider
HEI for a 6 Banger
Anyone got any suggestions on where to get a good deal on an HEI distributor for a straight 6 ??
I have a buddy who's building one. He just got the block and head back from the machine shop, so it will be a few days 'til he needs it. I did a quick check on Ebay and found some, but they're way too expensive. I paid a lot less for a V8 dizzy. Last edited by DB Smith; 11-04-2008 at 03:43 PM. |
11-04-2008, 04:58 PM | #2 |
I am a Referee of life.
Re: HEI for a 6 Banger
I bought one at the local Junkyard for $25.00 .I installed it just like I got it.I turned the rotor the same way as the points dist was when I pulled it.Timing wound up being about 2* off.It made a world of difference in driveability.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
11-04-2008, 05:46 PM | #3 |
i bought a points elimanator kit and it never failed me, but i heard that the later model stock hei ditributors are the way to go.
11-04-2008, 08:54 PM | #4 | |
Out of the carpool lane.
A brand new HEI shouldn't be more than $120 at any parts store. Keep checking the local yards and you should be able to find one.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
11-04-2008, 09:34 PM | #5 |
Yeah the stock unit puts out plenty of juice. I went stock. There's better ways to give them more power. Make sure to get the low rise cap with the external coil (Yes, it's still HEI) if you plan on getting AC for compressor clearance.
_______________ Thomas '78 Silverado '74 Monte Carlo '47 Teardrop Trailer East Texas Classics Local Club |
11-04-2008, 09:58 PM | #6 |
Funny, I was just thinking about possibly putting on my AC brackets and swapping out the internal HEI for external on my Camaro...
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... Last edited by Brad; 11-04-2008 at 09:58 PM. |
11-04-2008, 10:04 PM | #7 |
DB Smith, PM sent.
11-05-2008, 06:24 AM | #8 |
You might try Tom Langdon's:
www.stoveboltengineco.com
11-05-2008, 10:40 AM | #9 |
vw guy & now c-10 guy
The 68 truck I just bought has a 250 I6 with an HEI distributor, what year and model do you guys use to buy cap/rotor and plug wires? Do you still use the same spark plugs that you were running with points? same gap? thanks...
11-05-2008, 12:15 PM | #10 |
They came on cars and trucks at least in the range of '73-'78 and at some point went to the computer controlled HEI's. Just go to any parts store and get one for a C-10 in that range and you'll be good to go. Gap plugs to .045 or so and drive like ya stole it!
11-05-2008, 12:35 PM | #11 |
thanks brad, and btw, cool truck
11-05-2008, 05:57 PM | #12 |
I think when I went in the truck searches didn't come up with the external coil, but I could be remembering wrong. I do know I asked for a 75 Nova, and they got it for me.
11-05-2008, 08:39 PM | #13 |
Active Member
Can you explain how it affected the driveability?
I had thought of converting mine some time back, but read that there wasn't that much of a diffrence between the points and the HEI as far as gas mileage, power, etc., so I kept mine stock. |
11-05-2008, 09:18 PM | #14 |
That's total There's a huge difference in starting, driveability, and mpg's when you go to HEI. I knew it would be way better in my all original Camaro and it just about killed me to finally do the swap, but I couldn't be happier and I've never looked back!
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... Last edited by Brad; 11-05-2008 at 09:18 PM. |
11-05-2008, 10:08 PM | #15 |
TOTALLY!
11-05-2008, 11:08 PM | #16 |
I just tried searching for a hei dis with the external coil and did not have any luck. any one got a part #
11-05-2008, 11:35 PM | #17 | |
Active Member
Well, it may be total , but, IIRC I read it in an old cars magazine about about 15 years ago. They didn't say it wasn't better, just not that much of a difference in performance. Now mind you, I am not talking about a 350 V8 performance engine here. Just a single barrel 250... Can you be more specific other than the BS stuff? Like how much gain in hp or mpg on a 250 six cylinder. |
11-08-2008, 01:45 AM | #18 | |
www.stoveboltengineco.com I don't know the p/n, could be the title is the part nunber.
11-08-2008, 03:54 AM | #19 |
Sorry, I don't have any documented proof or dyno results, just seat o' the pants performance results along with better starting, mpg's, trouble free use, no points adjustment, etc...
11-08-2008, 12:51 PM | #20 |
You might want to call your local parts store too and let them look it up, mine was around $100 too.
11-09-2008, 01:18 PM | #21 | |
"Suggest extended tip design spark plugs which are designated by a "Y" suffix on Champion brand or "S" suffix on AC Delco brand. Suggested gap on these plugs is .60"-.80" for improved idle and low speed driveability". I used 8 mm Borg Warner HEI plug wires. |
11-09-2008, 03:07 PM | #22 |
Interesting....I'm just using the stock plugs. Let us know how it performs, and how the plugs look.
11-09-2008, 05:27 PM | #23 | |
Old Shovel Rider
Thanks, 68OS....That looks like the one we need. http://www.stoveboltengineco.com/aca...?productid=125 The internal coil type was what I thought we'd use, but they are way overpriced...$225 http://cgi.ebay.com/ebaymotors/HEI-C...Q5fAccessories Last edited by DB Smith; 11-09-2008 at 05:36 PM. |
11-09-2008, 05:34 PM | #24 |
Old Shovel Rider
11-09-2008, 06:16 PM | #25 |
Nope, that's a totally different animal....and ends up being $88 with shipping anyway.
