11-25-2002, 10:15 PM | #1 |
Project 7dos
Everyone who has 15" Wheels!!!<<<
can you post a pic of your 15" tire and wheel combo and give the tire size with the width of the wheel
THanks Jason
7DOS - 1972 C-10 350/350 Porterbuilt/Accuair 20x8.5/20x10 Ride Low or Die PSSST - Yes it's bagged. 7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290 |
11-25-2002, 10:39 PM | #2 |
WHYBYNU when old will do
Here you go.
front 15x8 with 255/60/15 rear 15x8 with 255/70/15 soon to change to TORQ- THURSTS 15X8 FRONT W/ 255/60/15 15X10 REAR W/ 275/60/15 Hope this helps !!
71 Cheyenne super 2 tone green and white ZZ6 - Th350 4/6 drop 20x8.5 / 20x10 Billet Specialties |
11-25-2002, 10:42 PM | #3 |
pic 2
Better pic of the rear.
11-25-2002, 10:44 PM | #4 |
15x8 w/ 275/60/15 tires all around.
1970 Sub C-10 - 350/TH-350/3.73 12-bolt Came home from the hospital in it & mine ever since. 1966 Catalina Ventura 2-door fastback 389/TH400 |
11-25-2002, 10:44 PM | #5 | |
Bloo
15x8 rallys with 235/75/15 mud tires on the back, this is the back tire
yeah i knwo it needs cleaning, but hey its a mud tire, i had to test it out
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
11-25-2002, 10:46 PM | #6 |
One more
old pic
front 3 in drop lower a arm, 2" drop spring 255/60/15 tire rear 3.5" drop block, with 3" drop spring 285/60/15 tire wheels are '90 454 SS 15" by 8" all the way around, 3/4" clearance between inner wheel well side and tire edge.
If patience is truely a virtue, Then I am so screwed 1970 Chevy SWB 331 sbc and all the goodies. Under resurection 2001 Vette |
11-25-2002, 11:00 PM | #7 |
15X8 with 255 -15 ralley
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
11-25-2002, 11:16 PM | #8 |
MPG...hmm..more like GPM
fronts are 215-60-r15's, rears are 295-50-r15s
the wheels on it are Appliance wheels, fronts i believe are 15x8's? the rears are 15x10's or they could be 15x12's not sure (they are big thats all I know ) anyway heres the pic,( it's an oldie, haven't got any new pics yet,it has a grille and the inner fenders in it now,
(Looking for 67-72 shortwide or shortstep bed) 71 C-10, 500ci of tire shredding Caddy torque, th400, 12 bolt w/Powertrax Lock-Right. Bald Rear Tires 85 Toyota 4x4- 22r 4-banger, 5 speed, I can actually AFFORD to drive this one. |
11-25-2002, 11:19 PM | #9 |
Active Member
Here you go, their 15"x8" 255 60's on the front and 15"x10" 275 60's on the rear. Wheels are wheel vintiques chrome ralleys, 6 lug with 67 style caps
69 Custom/10 454 Turbo 400 and 70 Custom/20 350 Turbo 350, 73 cheyanne C/10 also 69 camaro Z/28 and 85 Iroc Z |
11-25-2002, 11:28 PM | #10 |
225/70/15- not sure of width
-'02 Chevy Avalanche, 5.3L, 4x4... needing a small lift and bigger tires -'72 Chevy C-10(350, bored 60 over)dual flowmasters, 3 on the tree -'85 K5 Blazer,305 NO MORE...350 is in,2" lift,33" Mickey Thompson Baja Claw Radials -dads '70 burb (red, 5-7 drop, 350...) www.geocities.com/userc10/truckhome.html AIM: Auntjoedadda |
11-25-2002, 11:45 PM | #11 |
15x8 Ralleys...Semi-bald tires...Walmart modified caps. Eventually trim rings
11-26-2002, 12:00 AM | #12 |
15x10s with 295/50s all around, one coil cut out of front springs.
Brandon, SD 69 GMC 1/2 ton 2wd wide long bed with wood 3 on the tree 350 engine 4 bolt main rv cam AIM = Alphray04 |
11-26-2002, 12:03 AM | #13 |
440 american Horses
225/60 in the front, 285/70's in back.
Seth Petro 1969 Chev Short Step 425hp 350, TH400, big tires, fast truck 1979 Pontiac Trans Am 1991 Saturn SL1 - gas mileage! (and free) 1977 Buick LeSabre - for sale May America bless God, and may God bless America |
11-26-2002, 12:04 AM | #14 |
440 american Horses
here's a frontal view, rims are 15x7's up front, 15x10's out back
11-26-2002, 12:06 AM | #15 |
Project 7dos
Which number actually give you the sidewall height??
My Front sidewall and Rear sidewall are about the same...I want the front tire to be a bit shorter...How would i acheive this... Look at my front tire vs. my rear tire....I want a little bit shorter tire in the front... Thanks Jason
11-26-2002, 12:19 AM | #16 | |
Bloo
using my tire as an example--
235/75/15 it is 235 MM wide, or 23.5 CM, and the sidewall height is 75 percent of that, and it fits a 15" rim
11-26-2002, 12:22 AM | #17 |
Saving 1 truck at a time!
The second number gives you the ratio of the width to the side wall height. i.e. Tire size: 255/70, side wall height is 255mm x 0.70 = 178.5mm (7.027 in.)
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
11-26-2002, 12:26 AM | #18 |
-Praise the Lowered-
front wheels: 15 x 8 w/ 225/70 15
rear wheels : 15 x 10 w/ 275/60 15
Race-N-Jason ('71 Chevy C-10 LWB 454/TH350) ('07 Dodge Ram 2500, 5.9 Cummins/6-speed Manual) |
11-26-2002, 12:32 AM | #19 |
14.1 @ 96MPH
This pic is with my old Radial T/As on it, but I haven't yet snagged a pic of it with the Yokohama Avid S/Ts...same size, so you still get the idea
2.5" drop front, 4" drop rear, unknown width rims... 245/60TR15 front, 275/60TR15 rear. (That's the Yokos...the T/As are S-rated instead of T-rated.)
Project1970 - LS1 Swap Complete! |
11-26-2002, 12:40 AM | #20 |
huh?
I don't clean my rims/tires....they look crappy.
255/70/R15's in the rear, don't remember the front size, nor do I have a pic of them. Here are the rears, as stated, 255/70/R15, 15x8 vette rallies, with 6 on 5.5 bolt pattern:
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
11-26-2002, 12:48 AM | #21 |
14.1 @ 96MPH
That previous pic kinda exaggerates the rake...
Here's a closeup of the current treads.
11-26-2002, 12:56 AM | #22 |
wow, there's some NICE looking 15's around here
Brian Pal 1971 Cheyenne 10 454/th400-Undergoing a full frame off resto. 1972 Chevy short/step 2wd, 350/th350 1983 M1009 CUCV Military K5 Blazer 1981 Dodge 1 ton 4x4 dually flatbed |
11-26-2002, 11:16 AM | #23 |
I cannot post a picture, the browse feature keeps asking for a 640 x 0 size which I believe is a straight line.
Jim |
11-26-2002, 12:34 PM | #24 |
15x10 on the back with 295/50/15 and 15x8 on the front with 245/60/15s.....gives almost the exact same height (if I remember right, the front is like .1 inch shorter)
