Old 11-10-2008, 10:42 PM   #1
crm318
Alright Alright Alright
crm318's Avatar
replacing a steering gear box
my buddy has a 72 GMC truck that needs the steering gear box replaced. are there any special tools or techniques to replacing this thing?
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 11-10-2008, 10:54 PM   #2
cdowns
cdowns's Avatar
Re: replacing a steering gear box
a good puller for removing the pitman arm and make sure when installing pitman arm the box is centered(same#of turn to right and to the left)
Old 11-10-2008, 10:59 PM   #3
Painter D
Painter D's Avatar
x2
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs)
'63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs)
http://67-72chevytrucks.com/vboard/s...=528853&page=5
Painter D is offline   Reply With Quote
Old 11-11-2008, 12:14 PM   #4
WIDESIDE72
WIDESIDE72's Avatar
My experience with pulling pitman arms has not been good. Broke a cheap puller and a good puller. IMO, If it seems that it won't come off, I would heat the old one with a torch to give it some help get it off it. After you heat it, keep your welding gloves on and put the puller on it. It will pop right off. (I assume you have access to an oxy-acetylene rig). A propane torch will also work, just slower at heating it up.
WIDESIDE72 is offline   Reply With Quote
Old 11-11-2008, 12:18 PM   #5
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Buy a new rag joint while you have it apart.
the pitman arm puller can be loaned out from auto zone or other stores that loan tool.
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 11-11-2008, 01:35 PM   #6
cdowns
cdowns's Avatar
to properly use a puller you tighten it up to get tension on the part being removed then you take a hammer and smack straight down on the central bolt of the puller to relieve the tension then you tighten it again for more tension and smack it again keep repeating these steps and you wont be one of those people the destroys a perfectly good tool by improper usage
Old 11-11-2008, 03:43 PM   #7
Myself
I agree with the above. I have a cheapo puller that has been used countless times on jet ski flywheels, harmonic balancers,steering wheels, etc. Tighten it up, smack it with a hammer, repeat until it pops off.
Myself is offline   Reply With Quote
