11-12-2008, 11:44 AM | #1 |
How to remove bed by myself?
I have an engine hoist but need some ideas. I tried doing a search but only found how to remove cab. Thanks for any input.
11-12-2008, 12:08 PM | #2 |
Re: How to remove bed by myself?
this is how I did mine. Some 2x4's, one 4x4, and a long eye hook that went through both boards.
11-12-2008, 12:21 PM | #4 |
Next project: 1970 K10
Cheap and easy, I like it!
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
11-12-2008, 12:38 PM | #5 |
I wish I was a cowboy
How is the weight distribution on the bed? Looking at your ingenuity, seems like far more weight is forward of the wheel wells?
-Kris Met list: Cyclone,Wilson,TranzAm,extd56,hotrodhomi,mnky30,Rokcrln,Brad,JerryJones(well, his truck anyway). |
11-12-2008, 01:33 PM | #6 |
Active Member
Get you a stout buddy (I know there's someone out there that can help you) and just lift it off. That's the way I did mine. I placed a couple of saw horses with 2X4's across them behind the truck. We lifted up the rear and just pulled and eased it rearwards and placed it on the 2X4's.
11-12-2008, 01:52 PM | #7 | |
with the tailgate off there is more weight towards the front. It took a couple of tries to get it perfect, but once you do it will lift up perfectly straight. |
11-12-2008, 01:54 PM | #8 |
Also, I put the 2x4's under the lip of the bed to spread out the weight so it would not bend the bed rails. Worked very well.
11-12-2008, 02:08 PM | #9 |
Is it easier with the tailgate on or off? Also should I just set it on 2 sawhorses or put 2x4's across the sawhorses? Thanks for the picture and help.
11-12-2008, 02:18 PM | #10 |
Adam B
I used rachet straps and made and "X" with the straps across the bed. I then put my engine hoist hook in the center of the "X" and lifted it up from there.
It was fairly easy to do. |
11-12-2008, 02:38 PM | #11 | |
I already had the tailgate off so I didn't try with it on. I thought the lighter the better anyway. I didn't use sawhorses. I built a little stand with wheels out of some wood I had laying around as I wanted to be able to move it around. |
11-12-2008, 03:37 PM | #12 | |
When you build a stand like this, take into account the height needed to get the cherry picker legs underneath of it. It will save you some headaches.....ask me how I know |
11-12-2008, 05:09 PM | #13 |
454 MAKES IT ROAR
[QUOTE=Spray-Bomb;2971125]Redneck 101
Dig out the biggest toy you have Show Off!!
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
11-12-2008, 05:20 PM | #14 |
Tot Roddin'
Contact Rokcrln.... master fabricator!
Lewis Fabrication Design Inc. One-Man Cab & Bed Lift See it here~http://67-72chevytrucks.com/vboard/s...06#post1941906 Buy Here Now https://www.paypal.com/cgi-bin/websc...harset=UTF%2d8 Tip& Flip Cab Dolly (55-59 & 67-72) Buy Here Now http://www.bumpandgrindgarage.com/1213226.html
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
