11-14-2008, 06:49 PM | #1 |
"Tail Gate Best Seat In House"
How to install fuel sender and plug extra lines
I bought this Blazer Poly tank and sender just the way you see it in these pictures and was wondering what you all do to cap off the extra lines on the tank. I would rather not have these brass hose adaptors and would like a poly cap of some sort and glue it on.
Also pertaining to the rubber O ring for the sending unit. Is there anything to putting it on that I should know beings I have no directions . papa Attachment 403220 Attachment 403221 Attachment 403222
When you learn a thing a day you store up smart. Last edited by GOPAPA; 12-05-2008 at 04:05 PM. |
11-15-2008, 01:58 PM | #2 |
Re: How to install fuel sender and plug extra lines
I will elaborate a little more in hopes that some one will give me some tips on this tank installation ..
The brass fittings that are shown in my pictures that are extras I don't need have to be plugged or something to keep dirt out of the tank and that is for sure,,but what I would like to know is ,,,is there caps that they make to cap off these ports and if any one knows of any ,,I would like to know so to purchase them. And where the rubber O ring fit downs where it belongs ,,it "verily will reach the metal rim that clamps down over the ring to make it air tight ,,and was wanting to get some feed back just what others have done when encountering the same as I have .. thanks if you have anything to help me on this .. papa
When you learn a thing a day you store up smart. |
11-15-2008, 06:36 PM | #3 |
Can't help on the extra holes except go to the napa or other variety of auto parts and get brass plugs or rubber caps as needed for the extra holes. As far as the sending unit, place the oring on the unit after you put on the retaining ring. Put the sender in the tank and use a screw driver to tap the retainer into place in the locks on the retainer. It is a simple twist-lock design as you will see after start the install. Remeber also you will have to trim a crossmember on the bed floor so that there is no interference between the bed and tank (you will actually cut a section out of the crossmember) . What are you going to do for a filler? If you need a solution check out the build thread by Big J in KY, about half way through he doesa great pictoral and install of a gas door for one of these conversions. Hope this helps, Harold
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
11-15-2008, 08:31 PM | #4 |
you might b able to find something to cap the extra ports at a large hardware store or lowes homedepot//check swimmpool supply plumbing and sprinkler sections too
11-15-2008, 10:50 PM | #5 |
close-up of the brass fitting would help. are they threaded?
that would probably be too easy though... unless you felt like sawing them down and tapping them so you could just use some thread sealer or teflon tape and a threaded plug...
RN U OVR |
11-16-2008, 08:33 AM | #6 |
That's easy....simple vacuum line plug caps will work on the lines you don't need. You can get 'em in the help section of any parts store.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
11-16-2008, 10:36 AM | #7 | |
11-16-2008, 10:38 AM | #8 | |
thx ,,I will check em out ..will be better than them brass hose fittings sticking up that I would have to plug anyway .. papa
11-16-2008, 10:42 AM | #9 |
Now that it seems that there is no poly factory caps made for these poly tanks, like from the poly tank company ,,i will check out these stores for caps and the correct glue to plug the extra lines.. thx for the tips..papa
11-16-2008, 10:44 AM | #10 | |
They are not threaded ,,they are for a hose to slip on them with a clamp ,, thx for the tip though.. papa
11-16-2008, 10:59 AM | #11 |
Just a thinking outloud,,,errr typing out load ,,,,errr you know
Anyway, you could always just run a piece of fuel line between them. It would just create a loop between the tank and the tank. Frank
70 chevy lwb c10 454/th400 and a 9" rearend suicide doors, marker light fuel fill, 4" cowl , mini tub |
11-16-2008, 11:20 AM | #12 | |
I aim to find out and if it is so ,,this is what I will do to keep the tank cleaned up from all the extra stuff hanging off it.. "thx though" and if all fails ,,then your method is another to consider.. papa
11-16-2008, 11:35 AM | #13 |
laying low
Papa those brass fittings are screwed into the tank, correct? If so it's a simple matter of removing those and replacing them with brass pipe plugs, paint em black and be done with it.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
11-16-2008, 11:58 AM | #14 |
right? isn't everything threaded?
RN U OVR |
11-16-2008, 12:32 PM | #15 | |
Well , as I said before no one mentioned any factory caps like from the poly tank company so I went ahead and screwed them all out and got lucky and all seem to have good threads left to put plugs in the ones I don't use. I had no instructions with this poly tank and sure didnt want to create problems with a hurry up mistake ,,, so here I am Now knowing how simple it was by just unscrewing the pipe fittings and replace with plugs,, so thanks for all the advice ,,,and by taking my time it has worked out with out a foul up that would of cost me time and money.. Hope some one else with a poly tank install can get some good advice from all of this .. Here is a close up picture of the brass fittings that were in my tank tank .. papa Attachment 403706
