57 Chevy Truck wheel size
What is the largest, i.e. width and height tire that can be put on a 16" rim and still fit this truck in its stock configuration?
Re: 57 Chevy Truck wheel size
get your tape measure out and measure the wheel opening, side to side and depth then call your local tire store and ask. they should have the data on hand.
thanks, I tried all of the on-line tire companies and they don't list the largest if they list any. I searched the forum and no luck so I guess the tape measure is the way to go. I thought someone might have the info handy.
polishing a turd
let me check on the size i had on mine. the fronts would rub slightly when turned all the way, but that was with ooooold springs on it (probably original springs)
they are mounted on 16x7 wheels with 0 offset: ![]()
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512 53 buick special - straight 8 sled - blow through turbo 47 gmc - flatbed hot rod build 99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van' |
1-ton of fun, you read my mind that's what I am after.
polishing a turd
well i'm out of town until sunday, but i'll get the size for you then. they are actually for sale, but they are 8-lug wheels.
polishing a turd
265/75/16 is the size of those in the picture above
I appreciate the effort and the info. I just bought a 57 and I am shopping around while I take it apart.
Ron |
1971 Corvette convertible 454@ 525 hp ![]() 1936 Chevy Truck street rod 1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up 1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html 1950 custom Chevy Truck |
Cool site, that helps also.
