11-24-2008, 03:12 PM | #1 |
shaving hood side emblems
there is a support for the hood brace under the "3100 " emblem. how do you address that?
1971 Corvette convertible 454@ 525 hp 1936 Chevy Truck street rod 1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up 1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html 1950 custom Chevy Truck |
11-24-2008, 03:57 PM | #2 |
Re: shaving hood side emblems
If you are shaving the emblem then cut a small piece of metal that will cover the entire indention of where the emblem is and weld it to the hood! Simple really.
11-24-2008, 06:39 PM | #3 |
mine had some metal behind that emblem between the hood and the emblem and it was riveted and looked like it was going to be a general pain in the butt to get off so I just welded it in solid, drilled the rivets out and welded all the holes up.
11-24-2008, 07:57 PM | #4 |
///RELAXED ATMOSPHERE
I always cut out whatever indention im shaving and make flush filler and leave a 1/16th gap around perimeter for weld to fill then metal finish on outside and inside if inside shows........
Like a BOSS |
11-24-2008, 11:38 PM | #5 |
mine has the same, the rivet actually helps hold the hood brace in place, the rivet sticks out past the hood line. welding it ould work. also the emblem has 2 nuts on it that also help attach the brace to the hood panel.
11-25-2008, 12:08 AM | #6 | |
I didn't do it right on the first hood I had on the truck and the lines around the groove that the metal bar lays in showed up in the paint after a few months. |
11-25-2008, 12:51 AM | #7 |
I have seen that happen also. I may just put the emblems back on
11-27-2008, 11:19 AM | #8 |
I dont think I'll get ghost lines, I just welded everything up really well. The metal brace in there when welded ended up being flush with the outer skin so thats why I did it like that.
