Old 11-26-2008, 10:09 PM   #1
Rollinsqrbdy
Rollinsqrbdy's Avatar
73-87 crew cabs?
I really like the crew cabs. I got a friend whose selling me a 70? Crew cab 4x4 with an awesome 454 its a long bed. Now my question is can i put this body on a 85 chevy 4x4 long bed frame? I would also like for the truck to be a short bed. Any info on a transformation would be greatly appreciated. Thanks. Something like the pic.
Its Kool to be a square
2013 Chevy Silverado Z71 w/ 7" lift and 35" Nitto's
1985 C-10 ......My dream truck (under construction)
1984 k 10 Silverado...6" lift with 38.5 super swampers
New Mexico Member
--- Member of the Square Body Club---
Rollinsqrbdy is offline   Reply With Quote
Old 11-26-2008, 10:12 PM   #2
Rollinsqrbdy
Re: 73-87 crew cabs?
Dieselwrencher- ur trucks got me drooling for a crew cab. Nice truck, screw that, thats one bad a$$ frkn truck.
New Mexico Member
Old 11-26-2008, 11:47 PM   #3
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Thanks There used to be a crew cab short bed 85 running around here in Des Moines. It was pretty cool. Also, my brother has a 88 V30 crew cab that has a 5.9 cummins in it. It is going to get recabbed and repainted this winter, hopefully. For your question, I think you might have to lengthen the frame a bit or off set it by trimming the front of the box to make up for the short wheel base. We built a crew cab truck using a crew cab 2wd and used a burban frame. We had to lengthen it, I think, 4 inches if I remember correctly.
Dieselwrencher is offline   Reply With Quote
Old 12-04-2008, 03:42 PM   #4
Rollinsqrbdy
Can i make my friends 78 crew cab 2wd into a 4x4? How hard is it to take all of the 2wd front components off and put a leaf spring set up on it? I want to jerk all that stuff and make it a 4x4.
New Mexico Member
Old 12-04-2008, 05:31 PM   #5
Dieselwrencher
Not hard really. I jerked off all the old 2x4 stuff in a few hours. It all unbolts. I got a donor truck and robbed the shackles, front leaf spring mounts, engine crossmember, and steering box. On this crew cab truck, I used a 4"x4" 1/4" piece of square tubing and welded the front spring hangers to it. Then I measured where it needed to be from the donor truck. I also measured the shackle hole location and cut a hole in the side of the frame and drilled 4 holes for the shackle. I bolted the shackles on, installed my new leaf springs, and then bolted the front axle under it. I had to drill some new holes for the engine crossmember but it wasn't that bad. Then I swapped out the 2x4 steering box for the 4x4 unit. There might be a little more to it but that is the jist of it.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Old 12-04-2008, 07:04 PM   #6
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
Couple Pics i have saved...............
Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
toomanytoyz is offline   Reply With Quote
Old 12-04-2008, 07:45 PM   #7
Rollinsqrbdy
Well i talked to my bud today and got sum info. Its a 79 crew cab w/ a new 454 blue printed and balanced. Needs some body work but doable. He only wants $1,000. He's a good guy and he also has two carbs to go with it. The truck runs sweet. So it looks like im gonna be sleeping in the couch some time soon. Cause da wife aint gonna like another toy in the yard.. Dieselwrencher thanks for all the info, and tomany toys thanks for the pics. Now i got to go wipe off the drule. Thanx
New Mexico Member
Old 12-04-2008, 07:46 PM   #8
Rollinsqrbdy
Also what about the rear end? Does it matter any? Can i leave that?
New Mexico Member
Old 12-04-2008, 08:36 PM   #9
toomanytoyz
Luv the Crewcabs
With 4x4 you need Matching Axle gear Ratio............
Few More Pics i have Saved...............
Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
Old 12-04-2008, 08:59 PM   #10
Dieselwrencher
On my truck I chose to replace the spring hangers with 4wd ones because the 2wd front rear spring hangers are shorter and would require a bigger lift spring than you would need if you just swapped the hangers to 4wd style. Then I did a shackle flip and I only had a 4" block on the rear when the truck had 10" of lift. So basically you could have a 10" lift on the rear for some labor, a 4" block, and the price of u-bolts and 4wd hangers. My truck came with 56" heavy duty springs on the rear so if yours aren't as beefy actual lift heights may differ.
Ryan
Old 12-06-2008, 03:06 PM   #11
deer slayer
what are you guys doing for a frame
deer slayer is offline   Reply With Quote
Old 12-06-2008, 08:15 PM   #12
toomanytoyz
Luv the Crewcabs
I used ojoe's Method of Combining the Rear Half of a 1/2 Stepper Frame to the 3/4 Ton Crew Cab Frame. Look up Member ojoe & He has a Pretty Detailed Write-up of How to do it..............
Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
Old 12-07-2008, 12:32 PM   #13
deer slayer
im just not sure i want to trust that to pull alot of weight
Old 12-07-2008, 01:25 PM   #14
toomanytoyz
Luv the Crewcabs
Not Sure that I would either, That was not the Intent behind the Build. Can't beat a Stock Truck if Hauling is your Priority.................
Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
Old 12-09-2008, 06:01 PM   #15
JayG
Formerly ADHDCARGUY
JayG's Avatar
Cool job on the splice! Cool truck.
Jay
67CHEVY SWB,355, built 700r, 5/7,9",posi 3.50,REAR BAGS,HOOSIERS, A/C.
54CHEVY - BURB, beginning construction(well, i gotta take it apart first!)
36FORD PU - WAITING
38CHEVY - 2DR SD,CHASSIS FINISHED
46CHEVY - BURB - waiting
JayG is offline   Reply With Quote
Old 12-12-2008, 03:51 PM   #16
Prerunner1982
Prerunner1982's Avatar
This is still one of my favorite CC/short bed trucks.. of course there isnt a stock looking bed, but it is my insperation for a 4x4 project.
http://www.offroaddesign.com/willard.htm
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 12-12-2008, 05:32 PM   #17
884x4Sub
p p pullin'
884x4Sub's Avatar
that thing is cooolll!!!!
doug
884x4Sub is offline   Reply With Quote
