Old 11-29-2008, 09:45 PM   #1
silvereagle07
silvereagle07's Avatar
01 with a Low fuel light on with it full
I have an 01 that the lflight comes on at any given time. It is frustrating. Is this a common problem? Any help would be great.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 11-30-2008, 05:30 AM   #2
53burb
53burb's Avatar
Re: 01 with a Low fuel light on with it full
It's a common problem starting with the '99 trucks. I think GM corrected this problem a few years back. Anyways to correct the problem, you need to replace the sender in the gas tank. If you haven't replaced your fuel pump yet, (I assume you haven't because the problem would have more likely been fixed when the pump was replaced with the sender), buy a complete setup to include the sender & that should fix it.
53burb is offline   Reply With Quote
Old 11-30-2008, 07:06 AM   #3
1restorick
1restorick's Avatar
Before you drop the tank, try running some complete fuel system cleaner with Techron. Often the gauge problems occur with sulfur type deposits building up on the gauge rheostat. This stopped the problem on my 2002 Tahoe.
Rick
RED RUMBLE
1963 C10 Chevy Truck
Owned since 1984
1restorick is offline   Reply With Quote
Old 11-30-2008, 07:59 AM   #4
53burb
53burb's Avatar
I think the other problem was the wiring for the fuel pump/sender. The original harness that goes into the tank needs to be cut & replaced. I think that's what the problem was IIRC.
Old 12-04-2008, 02:13 AM   #5
53burb
53burb's Avatar
I stand corrected. When I needed to replace the pump on my '99, a new harness (4-pin) was replaced along with the pump. The plug was cut & the new harness was put in its place. I'm not sure why Chevy recommends this, but any place that sells the pump, usually has the new plug/harness, as well.
