Old 11-30-2008, 02:47 PM   #1
BigBlueBomber
700r4 and a bigger gas tank
Ok so i have been driving my burb alot more since gas went down. my tank seems pretty small for the size of the truck. I was wondering what size gas tank will fit and give more gas. The other thing I want to do is put a 700r4 in my rig. It is a 4x4 and what year tranny is best. I want to keep my NP 205 t-case. I was told that their is a certian years of 700's that are best and have the right parts. Thanks
BigBlueBomber is offline   Reply With Quote
Old 11-30-2008, 09:00 PM   #2
cparman
sharp as a marble
Re: 700r4 and a bigger gas tank
What you want is the latest model 700 that will fit to your Tcase. I would think you should be able to find one from a late 80's early 90's. Not sure but believe that there were updates to the pump. I put a 88 firebird 700 behind a zz502 = 500 hp big block in my Chevelle, and it stayed together with my right foot
cparman is offline   Reply With Quote
Old 11-30-2008, 09:20 PM   #3
BigBlueBomber
I was told that there is a certain tranny to get so that my T-case adapter will bolt to. It doesn't seem right though. Shouldn't all 700's have the same output shaft size/spline and bolt pattern for the tailshaft housing. My adapter bolts where the tailshaft housing goes.
Old 11-30-2008, 09:30 PM   #4
DINS 1
DINS 1's Avatar
go to advanceadapters.com they have all kinds of info on transmission and tranfercase swaps.
Wade
"DURAMAX BURB" Burb on 2004 chevy 2500HD 4x4 Duramax chassis Long term project
2004 2500HD 4x4 crew cab GMC Duramax 4" lift 35's
79 RS Camaro
DINS 1 is offline   Reply With Quote
Old 12-01-2008, 02:28 PM   #5
justcuz
justcuz's Avatar
You can do a search on Pirate 4x4 for NP 205 and Grumpy has a whole thread on the adapters and coupler lengths. You should find what you need there. They are not big fans of 700R4's so keep that in mind. It is a hardcore 4x4 website and they don't worry too much about overdrives on hardcore trail rigs.
justcuz is offline   Reply With Quote
