11-30-2002, 12:09 AM | #1 |
65 gmc stepside questions
I have a 65 gmc step side. Few questions.
1. It has rear leaf springs, I thought it should have rear coils. 2. Planning on swapping a 73 chevy front cradle in for disk brakes and 5 bolt rims. Any advice on this? 3. Any way to docode the number on the little silver plate above the door post? ABW |
11-30-2002, 05:58 AM | #2 |
abwdvm.................your right it should have coil springs........Yes you can decode the plate above the door pillar.........Give some numbers and I'll see what I can do for you.................HEMMIT
11-30-2002, 11:39 AM | #3 |
OK, titled 65 gmc, step side, 230, 3 speed. This truck has a 250 engine, was told the 230 went bad and was dealer replaced. I am the second owner, and I dont think the 1st owner would have modified the rear suspension.
Silver Tag GMC TRUCK DD l 1001 P F36106A Donor Cab (351E engine) GMC TRUCK DD 1002 p F45286A |
12-08-2002, 10:03 PM | #4 |
Hey abwdvm, 1. In those years GMC trucks, leaf springs were standard, where in Chevrolet, coils were standard. 2. Not familiar with that swap, but it sounds like a lot of work. If it were my truck, I would be leaving it original, but that's just my opinion.
12-09-2002, 04:27 PM | #5 |
65 gmc
Thanks! I thought it looked stock. I am pleased with the 3.54 ratio back there. Only thing I dont like is the 6 bolt axels. Wonder if I can use my 5 bolt axels and drum from the 73?
ABW |
