Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 12-03-2008, 07:46 PM   #1
EyeH8the24
EyeH8the24's Avatar
help with heater on a 97
my 97 s10 with a 4.3 dunno if that matters wont blow thru the vents ...only on defrost ,any help is apprecitated
EyeH8the24 is offline   Reply With Quote
Old 12-04-2008, 07:52 AM   #2
68C15
blood type; Retumbo
68C15's Avatar
Re: help with heater on a 97
sounds like you lost vacuum to the controls. defrost is the default position.
it feeds from the center drivers side of upper intake to a check valve between the booster and fender. there it branches off to the TX case, front axle actuator and another line leads to the interior. also make sure the hose at the reservoir is OK.
68C15 is offline   Reply With Quote
Old 12-07-2008, 12:37 PM   #3
EyeH8the24
EyeH8the24's Avatar
the resivoir hose was toast .....replaced it and it works thanks !
