Old 12-04-2008, 02:28 AM   #1
trenchwarfare
'90 sub exhaust?
I cut my exhaust off a while ago from the muffler back. I've been searching around for a decent priced dual bolt on kit. I don't care too much about mufflers as i'll throw a pair of glass packs on. My main concern is that most of these systems are for 87 and older. Will they bolt on the same as long as it's for the 350? I'd also like to get some headers.
Will this fit? I'd like 3", but it may work.
http://www.lmctruck.com/icatalog/csb/full.aspx?page=120
____________________________________
trenchwarfare is offline   Reply With Quote
Old 12-04-2008, 10:10 AM   #2
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: '90 sub exhaust?
Can anyone help?
I would think it would be to short for a burb, but I may be wrong.
TRva
tvblazer78 is offline   Reply With Quote
Old 12-04-2008, 02:36 PM   #3
screwballl
Tonawanda 454
screwballl's Avatar
the exhaust should be the same for all burbs (small extra turns here and there) from 81 to 91
I may have to go that route with mine since none of the local shops will touch it because of the cat requirement (mine has not had it since before I bought it)
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!!
04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011)
In the past 30 years about 90% of Fords are still on the road, the other 10% made it home.
screwballl is offline   Reply With Quote
Old 12-04-2008, 03:36 PM   #4
trenchwarfare
What did you end up with yours? Any photos?
Old 12-08-2008, 12:58 PM   #5
screwballl
Tonawanda 454
screwballl's Avatar
I went with a single 3" (due to 454) on mine not too long after I got it... no photos ATM but will post some later
Old 12-10-2008, 03:11 PM   #6
turbotank
turbotank's Avatar
As far as I know,all suburban exhausts are the same from 81-91,and 87 exhausts will definitely fit,as they did not want to spend anymore money on the 88-91 suburbans,cept to make them look like there other trucks up front,cause they were planning on changing them.
The general is always in charge
You guys did this to me!!!!!!!!!!!!!!!!!!!!
turbotank is offline   Reply With Quote
