Old 12-04-2008, 06:04 PM   #1
Lrall
Lrall's Avatar
brake question!!
I am in the process of putting my brake booster/MC back on. I'm wondering if i need to bench bleed the MC or what. It was on the original s10 and all the fluid has since drained out. If i do could someone give me a quick write up on the proces? I also need to figure out the brake lines, i have a big and a small, is there one way they hook up or? Thanks for the help!!
lr
Lrall is offline   Reply With Quote
Old 12-04-2008, 10:09 PM   #2
54 jimmy
54 jimmy's Avatar
Re: brake question!!
the big line goes to the rear brakes and the small to the front. i am using the s10 master and prop valve. hope the pic helps.
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver) sold
1996 chevy k1500 reg cab 4x4(daily driver)totaled
2008jeep patriot (wife's daily driver
2008 chevy 1500 ext cab 4x4 sold
2011 chevy 1500 crew cab ltz (daily driver)
1996 chevy 1500 reg cab 4x4 project sold
2006 pontiac grand prix gxp (daily work commuter)
54 jimmy is offline   Reply With Quote
Old 12-04-2008, 10:20 PM   #3
notah
Yes bench bleed the master cylinder. Get some old brake lines, screw them in the mc and bend them so that the ends are back in the resivoir. Put the mc in a vise, fill it up with brake fluid, and use a screwdriver to pump the mc like the pedal would when you push it. Do this until there is no more air bubbles.
james
notah is offline   Reply With Quote
Old 12-05-2008, 01:04 AM   #4
JML55
JML55's Avatar
Usually the bigger line is the front calipers, bigger piston then the w/cyl in the back need more fluid.
Jean-Marc Lacasse
57 GMC
55 GMC
55 Belair
99 S10
http://67-72chevytrucks.com/vboard/s...d.php?t=316140
http://67-72chevytrucks.com/vboard/s...d.php?t=806011
JML55 is offline   Reply With Quote
Old 12-05-2008, 03:12 AM   #5
Lrall
Lrall's Avatar
Im using an s10 so im assuming 54 jimmy is right. And i thought i would need to bench bleed the MC but i was just checking. Really the big line is at the front but powers the rear breaks. Thanks guys!!
