Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 12-05-2008, 11:56 PM   #1
shrtbx
soft touch rev control?
What does a soft touch rev control do?
shrtbx is offline   Reply With Quote
Old 12-06-2008, 02:42 AM   #2
djracer
djracer's Avatar
Re: soft touch rev control?
It makes the ignition misfire to limit rpms.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 12-10-2008, 08:32 PM   #3
Ryan Hubbard
It randomly takes out cylinders to control the rpms at the rev limit. SO you are not loading up a few cylinders.
Ryan Hubbard is offline   Reply With Quote
Old 12-10-2008, 10:03 PM   #4
Marv D
Registered Truck Offender
Marv D's Avatar
Like said, it drops random cylinders, and the processor will not take out the same cylinder two cycles in a row. With the old studder boxes the ignition was in effect shut of and on repeatedly to keep rpm's from going over a set limit. This caused cylinders to load up with fuel and very often a big ol bog at the launch, or dead cylinders for the whole pass. The 'soft touch' was developed by Mallory if I remember correctly and is now a standard (in some form by numerous names) in all rev limiting ignitions.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
