Old 12-09-2008, 09:27 PM   #1
big dump
big dump's Avatar
A/C Noise
Recently on our '04 Tahoe, when we turn on the A/C, and turn the speed up on the higher settings, it makes a really loud buzzing or humming noise. It has the climate control style A/C where you set the temp, and it adjusts automatically, but you can turn the fan speed up or down also. It makes the same noise in the higher fan speeds regardless of whether I turn the temp up or down (A/C or Heat). My brother has a similar issue in his '99 GMC Sierra, but he has the numbered settings 1,2,3,4 with the single temperature knob. Seems to work fine on the lower settings regardless of the temp, but not on the higher speeds. High Speed Fan Relay? Any ideas?
Thanks,
big dump is offline   Reply With Quote
Old 12-10-2008, 01:40 PM   #2
big dump
big dump's Avatar
Re: A/C Noise
Nobody?
Old 12-10-2008, 02:19 PM   #3
truckdude239
truckdude239's Avatar
Re: A/C Noise
sounds like the fan is going if it is buzzing
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
