Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 12-10-2008, 03:13 PM   #1
joeys66pickup
Dr. Frankenstein
joeys66pickup's Avatar
Anyone with Lexan?
how did you mount it? im going to do the side and back windows but dont really know how to mount it SAFELY...help
I Wanna Go Fast!!
joeys66pickup is offline   Reply With Quote
Old 12-10-2008, 03:21 PM   #2
d10s69c10
Built 4 Speed
d10s69c10's Avatar
Re: Anyone with Lexan?
the safest way to do it is to screw/bolt it from the outside. of course you can cut it right and just seal it in like a glass window. since lexan bends im always kind of worried about an edge coming at me in the event of somthing bad happening.
did all the windows on a s-10 a few years back just used self tappers the whole way around and then siliconed it smooth on the outside. this was strictly a drag truck tho and the job wasnt pretty.
1969 C/10 Short Box:
496/T-56 in worx.
"To Be Old And Wise, First You Must Be Young And Stupid"
d10s69c10 is offline   Reply With Quote
Old 12-10-2008, 03:34 PM   #3
joeys66pickup
Dr. Frankenstein
Sweet Thanks! hahaha i dont think i have EVER worried about "Pretty"
Got any pics?
I Wanna Go Fast!!
Old 12-10-2008, 03:36 PM   #4
d10s69c10
Built 4 Speed
d10s69c10's Avatar
i wish i did for you. i hardly got the image left in my mind but if i go to the track tonight ill see if i can find you a photo or 2.
maybe someone here has one?
496/T-56 in worx.
Old 12-11-2008, 03:28 PM   #5
djracer
djracer's Avatar
To do it right you use rubber to bring the lexan out flush with the body and use counter sink screws. You should paint a black border around the edges. To do this tape off the part you don't want painted and sand and paint it on the back side.
A right angle electric or air grinder with a sanding disc helps to shape the lexan once you get it close to the right size with a jig saw.
For side windows in our trucks I would use aluminum channel to mount the lexan in the track.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 12-11-2008, 04:49 PM   #6
hotrod 80
mini truck racer
hotrod 80's Avatar
For my back window I used the original rear window to cut the initail shape of the new window . I then used a compass set at 1/2 " and scribed a mark around the cut out window shape . My Lexan came with plastic on both sides of the window to protect against scratches . The scribe mark cut this plastic and i pulled it off . Buffed it with a scotch brite pad and painted it black to clean up the look . I put it in place and drilled all the holes . Ran a bead of winshield latex around the frame and pop rivited it in the indention . Then i pulled the plastic protectant after everything cured . It came out pretty good i think .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 12-11-2008, 04:55 PM   #7
joeys66pickup
Dr. Frankenstein
THANK YOU ALL FOR YOUR HELP!!!!! now once this is done i will get some pictures up...
I Wanna Go Fast!!
