Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 12-13-2008, 06:29 PM   #1
LuckyHenriksen
LuckyHenriksen's Avatar
Tire Height
If I am running a 3:73 gear and a TH400 with a 4500 stall, how tall of a tire should I run? I am looking to buy a set, I drive a lot on the street, but would like to hit the track. Any opinions on what brand/type?
1968 Yenko Chevy LWB
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
LuckyHenriksen is offline   Reply With Quote
Old 12-13-2008, 07:01 PM   #2
Super73
Super73's Avatar
Re: Tire Height
There are a few things to consider.
Pros:
Height helps to hook
Height typically last longer as to go the same distance, you need less revolutions (Assuming the same gear ratio is used)
Height brings freeway rpm down
Cons:
With out the right gear, your set up is not optimized and you might not be running to your full potential (ET)
With out a lock up converter, too tall of a tire may keep you slipping the converter some and creating heat.
But I'd think a 26" or a 28" would be ok.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 12-13-2008, 07:46 PM   #3
LuckyHenriksen
Re: Tire Height
OK thanks, I am trying to find a set for now, I need some wider ones to fit my new wheels. Will look for some 28'' ones.......
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Old 12-13-2008, 08:59 PM   #4
68 C-10 KID
Mean Green
68 C-10 KID's Avatar
Re: Tire Height
With the 28" and the 3:73 Ratio you can cruse freeway speeds any where you want no problem. With that big of converter I recommend running a big trans cooler and never run it through the radiator, that's hot all ready.
@ the track its going to be a little piggish till it gets on top of the
the optimum set up i like to see is a 4:30 w/ a 28"
68 C-10 KID is offline   Reply With Quote
Old 12-13-2008, 10:43 PM   #5
Super73
Super73's Avatar
Re: Tire Height
Gear tire combo for the track is relative to max RPM IMO. There is no perfect one stop gear/tire combo.
But yeah, make sure you have a decent trans cooler.
Old 12-16-2008, 11:54 AM   #6
djracer
djracer's Avatar
Re: Tire Height
I ran a mickey thompson sportsman pro that was 12.5x28 with a 3.73 in my old street truck with just a decent 350/350 and it worked well on and off the track.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 12-16-2008, 09:36 PM   #7
LuckyHenriksen
Re: Tire Height
Allright thanks for the replies guys. It would really be nice to cruise the freeway at least semi-comfortably.
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
