Old 12-18-2008, 10:22 AM   #1
bigbadchev72
People know me
bigbadchev72's Avatar
5.3 Idle problems
Just recently since it has gotten cold outside 20 degrees and below, our tahoe has been having some problems. I went to start it the other day and it fired up and died immediatley, I fired it up again and the same thing, I can get it started and give it gas and it will run, After about a minute it will idle on its own, But its up and down in rpms.
It has 83k on it and is the new body style, yesterday I changed out what appeared to be oem plugs, wires, fuel filter, and air filter, Cleaned the map sensor, and throttle body.
Right after all this started I figured it was water in the fuel so i dumped a bottle of prestone water remover in a 1/4 tank of gas and some injector cleaner as well.
I fired it up this morning when i got home and it fired right up and stayed running went right up to 1500rpm then down to a slightly rough 1000rpm then back to 1500 for about 5 seconds then back and forth.
Where should i go from here? No check engine light is on
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels
1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels
bigbadchev72 is offline   Reply With Quote
Old 12-18-2008, 11:00 PM   #2
Blaze69
Blaze69's Avatar
Re: 5.3 Idle problems
What year is it?
1969 Blazer: 350/350, 4X4, HEI, Edlebrock carb/intake, dual flowmasters, np205, 3:07's and the rest is mostly stock.
The front end disc swap is finally complete
2002 Z71 Tahoe. CAI, Flowmaster 40, Silverstars in high, low and fogs and a bunch of mods (upgrades) inside and out.
Blaze69 is offline   Reply With Quote
Old 12-18-2008, 11:12 PM   #3
bigbadchev72
People know me
2000 new body style, I cleaned the IAC and so far so good.
Old 12-18-2008, 11:36 PM   #4
truckdude239
truckdude239's Avatar
Vacuum leak of the intake gasket
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 12-19-2008, 12:11 AM   #5
Blaze69
Blaze69's Avatar
Yup, wan't sure of the year, but that is where I would have sent you looking for a place to start.
