Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 12-22-2008, 08:26 PM   #1
Crumley
Crumley's Avatar
72 GMC 4x4 rebuild
I figured since I am waiting on parts, I would start a build thread on the 72 GMC. Here are some picture right after I got it home. This truck is decent shape it needs cab corners and rocker panels (as usual). The floor boards have a small amount of rust but can easly be taken care of with a wire wheel. The inside of the doors will need attention as wall as the cowl area. A PO left it sitting under some old oak trees. There must have been 50lbs of leaves, sticks, acorns and other debris down in the windshield wiper well.
Crumley is offline   Reply With Quote
Old 12-22-2008, 08:40 PM   #2
Crumley
Crumley's Avatar
Re: 72 GMC 4x4 rebuild
Some additional pictures of the dissasembly. Front sheetmetal removed. Engine out, down to running gear and frame. Rear end removed.
Old 12-22-2008, 08:58 PM   #3
Truck Hippy
Truck Hippy's Avatar
Thats a good looking truck to start with and a helluva shop to work on it in.
Truck Hippy is offline   Reply With Quote
Old 12-22-2008, 09:01 PM   #4
Crumley
Crumley's Avatar
More pictures and its down to the bare frame. At this point it will be alot of wire brushing and scraping off very thick under coating. Lots of labor. Suprisingly a very rust free frame.
It looks like it has neve been wrecked and cross measures correctly. After weeks of cleaning and preping I finally brushed POR 15 on the frame. This stuff runs like water.
Starting reassembly, new 6" lift springs. At this point the camera has knoked out on me, I have got to get a new one.
Currently the running gear, engine, trans, transfercase, drive shafts, gas lines, brake lines, emergeny brake cables and exhaust have been installed.
I will up date with picture when I get another camera.
Old 12-22-2008, 10:31 PM   #5
Fubar
Fubar's Avatar
Nice project, and nice shop! I love seeing 4x4 build's, keep the updates coming please.
Fubar is offline   Reply With Quote
Old 12-22-2008, 10:36 PM   #6
msgross
msgross's Avatar
nice build, this will be a big truck... be sure to check in those side vents if the cowl was full of leaves!
Here was mine
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 12-23-2008, 01:04 AM   #7
Rack Man
Nice....Keep the pics coming !!
Dan
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288
Rack Man is offline   Reply With Quote
Old 12-23-2008, 01:30 AM   #8
dieselarmy13
Phone's ringin Dude.
dieselarmy13's Avatar
Sweet. Cant wait to see more pics. Gonna keep the extra 6 inches? I'm suprised Andy and all of the other Longhorn/Custom Camper nut's haven't caught this one yet.
I pitty the fool with only two headlights!!
2003 SILVERADO SS--THE NEW GIRL
1972 GMC--THE OLD GIRL
dieselarmy13 is offline   Reply With Quote
Old 12-23-2008, 08:18 AM   #9
Crumley
Crumley's Avatar
Thanks for the replys. The shop (man cave) is a 40 x 60 (Finished it in 2007) and it still isn't big enough (they never are), i enjoy spending hours out there.
10-4 on the the leaves in the side vents, It took a vacuum cleaner and air hose to get them cleaned out. When I start the work on the cab I will cut into the side vent area and work on what ever rust has started in those areas.
I will run the 6" lift with 33 x 12.50 or 35 x 12.50 tires on either 15 x 10 aluminum rims or 15 x 12 widened 4 x 4 rally wheels. If ends up driving like crap I will put the old stock leaf spring and steering arm back in.
Old 12-23-2008, 08:45 AM   #10
sdailey
The Few, The Proud
sdailey's Avatar
First off from North GA.
Good luck on the build. It looks like it's going to be a sweet truck when you're done. Loving the "Man Cave" as well. I'm hoping to build a 30 x 30 myself this coming year.
As far as the lift goes I'd run 35's instead of 33's with a 6" lift.
Holler if you ever need anything.
Shannon
sdailey is offline   Reply With Quote
Old 12-23-2008, 10:23 AM   #11
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Lookin good! Keep up the good work!
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 12-23-2008, 03:26 PM   #12
ChaseDale3and8
ChaseDale3and8's Avatar
Looks like a really nice truck to start with. Nice looking shop to work in too! Good luck with it and be sure to keep updates! ...Joe
I'm not speedin'! I'm qualifyin'!
ChaseDale3and8 is offline   Reply With Quote
Old 12-24-2008, 08:04 AM   #13
nuke1
nuke1's Avatar
i will agree on the tire choice, 33s will look smalll on her with a 6 inch lift, by the way nice vette in the garage.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 12-27-2008, 09:45 AM   #14
NEVERENOUGH
NEVERENOUGH's Avatar
Very cool project and like everyone has said very nice shop. I think you will like the 35's better when it is all said and done. Can't wait for more pics.
NEVERENOUGH is offline   Reply With Quote
Old 12-28-2008, 04:47 PM   #15
ChaseDale3and8
I'd go with 35s on a 6 inch lift. On the 71 GMC 4x4 that I used to have I put a 4 inch and 33s on 10 inch wide wheels. It looked good and no tire rub. I could have run 35s on it if I had wanted to because there's a LOT more room to work with than on the 73-87 body style! ...Joe
Old 01-02-2009, 08:08 PM   #16
Crumley
Crumley's Avatar
Well I have gotten another digital camera and figured I would try it out. So here are some current pictures of the rebuild.
Nuke1 the vette is a future project. It currently is a driver to go to cruse-ins while I work on the truck.
My plan is to run 35x12.50 on 12"wide GM 4x4 ralleys.
Old 01-02-2009, 08:18 PM   #17
msgross
msgross's Avatar
did you do the exhaust, was it a kit?
The Garage:
Old 01-02-2009, 09:06 PM   #18
Crumley
Crumley's Avatar
Nope not a exhaust kit. The PO had just installed a new exhaust system before I purchased it. I had to modify the exhauxt system and e-brake brackets due to the 6" lift (I didn't want to scrap the existing exhaust system). Trying to save money anywhere I can.
I had to move the emergency brake brackets from the top of the frame to the bottom of the frame to get the e-brake cables to work. When I changed the emergency brake bracket/cable location the mufflers interfered with the relocated e-brake bracket. So I had to cut the exhaust system apart and change the muffler location to get it all to work.
Old 01-07-2009, 09:17 PM   #19
NEVERENOUGH
I love this project and can't wait to see some more pics of it.
Old 01-08-2009, 04:43 PM   #20
ChaseDale3and8
Your chassis looks great! ...Joe
Old 01-08-2009, 06:26 PM   #21
jeremy zander
jeremy zander's Avatar
Great project. por15 looks good..Are you going to put a new gas tank under the frame too??Keep up the great work....!>>!>1.!>1...
WTB 1972 CHEVY 3/4 4X4
1971 chevy c30 4x4 NAPCO (project)
1972 chevy 3/4 4x4 350/350 4spd, tach, tow hooks,radio delete,heat delete,hubcaps,lockers
1972 chevy 3/4 4x4 383/350 dads original farm truck tilt,tach,tow hooks,hubcaps,radio delete,heat delete
2006 chevy LBZ crew cab duramax,4 inch,beadlocks
2015 chevy tahoe Z71 my fifth one,love em
2016 chevy 2500HD Z71 LTZ duramax midnite
2018 chevy suburban Z71 midnite
jeremy zander is offline   Reply With Quote
Old 01-09-2009, 07:26 AM   #22
Crumley
Crumley's Avatar
I have debated back and forth about the gas tank location. Right now its looking like I will install the gas tank back in the stock location behind the seat. I don't want alot of money tied up in the truck (it will be my shop truck) and getting a gas tank to mount in the rear is just additional $$$ that can be spent on other items. My only concern about the stock location is the filler neck to cab gasket. From what I have read on here no one is making a decient cab to filler neck gasket, or one that doesn't start cracking after a few short years. If anyone knows of a place that has a decent gasket please let me know it would be much appricated.
Old 01-10-2009, 09:41 AM   #23
Crumley
Crumley's Avatar
Its time to start on the cab. Nothing like thick undercoating to scrape off, oh joy. Well I guess its time to get the oxy./acet. tourch and scraper out. Heat this stuff up and scrape it off. Ahhhh, the smell of of burning hot tar.
As you can see by the pictures the rocker panels are eat-in up with cancer. The inners have been rusting out from the inside, so they will be replaced also. Hopefully that will be the extent of the rust. If you look at the picture of the top of the cab, there is a CB antenna hole right in thr center of the cab,that will need to be patched.
Old 01-24-2009, 08:47 PM   #24
Crumley
Crumley's Avatar
More updates: Removing the under coating is a stinking filthy job but that is behind me now. I didn't re-under coat the outter portion of the cab due the the work that still nees to be done on the rocker panels and cab corners. Stripping paint off of the cab and re primering. Repaired CB antenna hole in roof, repaired small rust thru holes each side at lower back window, cleaned and primed and painted the radiator core support.
Old 01-24-2009, 11:32 PM   #25
NEVERENOUGH
Truck is coming along nicely can't watit to see it rolling again.
